Old 06-04-2005, 01:27 PM   #1
full foot notch
real differences between D44 and 8lug D44???
alright, front of my explorer is done, and its got a 6lug blazer D44 under there that i got from a local board member
well in the garage i have a 8lug "HD" D44, that was pulled from a 87 V20 work truck, and was going to install the crossover setup i have for the steering on my explorer
but i was wondering what the primary differences between the 6 lug D44 and the 8lug D44, i know about the spindle and bearings difference and all that, but was wondering if the axle shafts were different, IE if the 8lug D44 axle shafts might be any thicker/better than the 6 lug D44, or do they use the same axle shafts and the only difference is the spindles and hubs
cause my idea was to swap everything that was better from the 8 lug into the 6 lug axle since its already under the truck, or still go ahead as planned and install the 8 lug axle, but in the back of my mind, thinking it would be redundant to install the same axletubes and shafts if the only difference is the spindles and hubs
full foot notch is offline   Reply With Quote
Old 06-04-2005, 10:52 PM   #2
kwmech
First off there is no such thing as a 1987 dana 44. The last 44s were in 77 or 78. It may be a 10 bolt. If the 44 under your truck is later than 71, then the outer shafts and splines will interchange, u-joints are the same. Either way, keep the 44 shafts and you can go ahead and swap everything from the spindle out. Spindles, hub/rotor assy, backing plates. If you want you can use the 6 lug calipers so you do not have to crack the brake system.
