Old 04-11-2002, 06:41 PM   #1
RipMeyer
RipMeyer's Avatar
Post How Many Have A/C Thats Works?
How many of you have an A/C cab with the A/C that works correctly? I have seen quite afew of these trucks and quite often the A/C has been hacked up or removed all togeather. Why do people feel the need to CUT the A/C out with a hacksaw?
Anywaym, mine is a 69 and the A/c works great.
RipMeyer is offline   Reply With Quote
Old 04-11-2002, 07:10 PM   #2
woodmancfh
GMC RULES
woodmancfh's Avatar
Post
I have a 72 GMC and the air is so cold it will freeze you out of the truck. -Craig
70 Chevy C/20
72 GMC K /2500
woodmancfh is offline   Reply With Quote
Old 04-11-2002, 07:27 PM   #3
Project1970
14.1 @ 96MPH
Project1970's Avatar
Post
Mine does, when there's Freon in it. I think it lost a lot more than the usual can's worth this winter, though...I'm putting more in tonight.
Project 1970 - soon to be seen at http://milhouse.treylis.org:81/
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 04-11-2002, 07:42 PM   #4
nroden
nroden's Avatar
Post
Mine works but takes a little bit to get cold. Needs more Freon put into it.
Hasn't had anything done to it in 30 years so its about time.
I take that back. My great uncle did run a toggle switch to shut it on and off since the switch built in doesnt work but we're gonna fix that soon.
Nick Rodenberg
Wellington, MO
http://nickrod.port5.com
You can click on "My 72 Chevy Truck"
I have a 72 Cheyenne 10 with a V8 350 and a TH-350 auto-tranny.
White/Ochre/White
Runs well... working on body.
Hoping to have completed in March when I turn 16
Nick Rodenberg
72 Cheyenne 10 V8 350/TH350
white/ochre/white/ochre, ochre/saddle interior
Retired and in the dry... still runs. I now drive Red '01 Ford Focus... better MPG!!!
nroden is offline   Reply With Quote
Old 04-11-2002, 07:45 PM   #5
Mike C
Mike C's Avatar
Post
Both of mine work, the one in the truck is awesome, but the Jimmy has just too much interior space for the same AC unit. The truck looks like the clutch is leaking oil, so it won't be long for this world...
70 GMC 3/4 ton Sierra Grande 402/TH400
72 Jimmy 4WD 4spd 4" & 35's
64 Corvette Coupe
68 Camaro 'vert TPI & TH700
69 Z/28 355 12.6's @110
72 Datsun 240Z-ol' reliable
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
02 GMC 2500HD 4x4 Duramax
Old 04-11-2002, 07:55 PM   #6
barn9
Half a bubble off!
barn9's Avatar
Post
Mine works, but needs some freon every summer.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 04-11-2002, 08:08 PM   #7
RipMeyer
RipMeyer's Avatar
Post
Now for the next question. What do you use to recharge it?
I was thinking on using DuraCoolŪ. Direct replacement for R12. No modifications needed and suposed to be a tad bit cooler.
Old 04-11-2002, 08:24 PM   #8
Andy4639
Old member
Andy4639's Avatar
Post
I up graded to 134-a in mine, and have had no problems with it. You can see it on my web sit in signature, also put 80 model stuff in it to clean up the fender. No poa valve. Works great! Here is the outside part.
Andy
71's Are for ever!!! or 67,68,69,70,72
<A HREF="http://www.geocities.com/chevy71tpi/main.html]]www.geocities.com/chevy71tpi/main.html][/URL" TARGET=_blank>
[URL=http://www.picturetrail.com/Andy4639]]www.picturetrail.com/Andy4639]</A>
[This message has been edited by Andy4639 (edited April 13, 2002).]
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 04-11-2002, 08:45 PM   #9
Riptide
Thumbs up
You guys with AC are so lucky. It would be so great to have a truck with AC. Some day I'll find an aftermarket kit and adapt the cab. Till then you guys stay cool and I'll keep the windows down.
67 Chevy C10
67 Chevy C10
McPherson, Ks
"Remember Don't Sweat the Petty Things, Pet the Sweaty Things"
Riptide is offline   Reply With Quote
Old 04-11-2002, 08:51 PM   #10
chevyman 68 C/10
chevyman 68 C/10's Avatar
Post
My 68 custom still has the same freon that came in it ,as far as I know. I have had it for 6 years and never had trouble. It will freeze your_ _ _ off
69 Chevy short fleet side soon to have LT1 and 4L60E pb. ps cruise and air.
68 Chevy short fleet side 400 sb 5 inch chop top pb. ps. pw. 350 auto and shaved handles
68 anniversary no engine long wheel base 400 auto FOR SALE
68 Chevy fleet side long wheel base complete parts truck.
chevyman 68 C/10 is offline   Reply With Quote
Old 04-11-2002, 10:34 PM   #11
JQ-72
JQ-72's Avatar
Post
2 out of my 3 72's blow cold air. The third truck will too if you gas it up every three months!
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track
72 Cheyenne Super swb. 350/350 A/C, bucket seats
72 Cheyenne swb. Factory 402/400, tilt, posi, A/C
72 Cheyenne Super K-10. 350/4 spd., posi.
72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack
72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior
JQ-72 is offline   Reply With Quote
Old 04-12-2002, 12:23 AM   #12
Zurbo
Zurbo's Avatar
Post
Mine is working great.
Went all through it a year ago and kept it POA with r12.
Zurbo's Chevy - 1972 Black/White Cheyenne Super. 400 Big Block /THD 400, factory air and tilt.
My other Chevy - 1998 Camaro SS
Zurbo's Chevy - 1972 Black/White Cheyenne Super. 402 Big Block /THD 400, factory air and tilt.
Zurbo is offline   Reply With Quote
Old 04-12-2002, 01:38 AM   #13
Joesjunk
Joesjunk's Avatar
Post
I have a 60k mile original truck that blows cold. Never done anything to it.
1972 3/4T 402/auto 60k original miles, original paint
1971 1/2t 4x4 frame restored, original paint body put back on it
1968 1ton dually CST 52k original mile, restored
1972 1ton dually cheyenne flatbed, scrap hauler
1972 blazer,rust free, original paint, next project
72 2wd blazer for the above rust free body
1972 3/4t 4x4 GMC, For sale
1968 1/2t 4x4, For sale
72 2wd jimmy, for sale
1969 camaro ss396 4-speed, restored stock
Other67-72 parts trucks
Lots of parts for sale
2001 GMC 2500HD 4x4 diesel, I have to have something to drive to work everyday
Independence, MO
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 04-12-2002, 05:43 AM   #14
custom camper 20cst
Post
My 69 ac works great have never had trouble[knocking on wood]
custom camper 20cst is offline   Reply With Quote
Old 04-12-2002, 10:49 AM   #15
busterwivell
Post
My 71 is a factory A/C truck, but it never worked since I bought it. The belt wasn't on it. The under dash unit has an "S" shaped piece that fell off and is under the seat. Now the fan has quit working. I've been debating what to do, and I think I'm leaning toward taking it all out and putting in a Vintage Air setup. I talked with them at Goodguys - DelMar last weekend. they have a complete system for our trucks for $1095.00. What would you do?
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 04-12-2002, 08:44 PM   #16
racedvl
racedvl's Avatar
Cool
My a/c works great every time I roll down the windows.......
http://hometown.aol.com/racedvl/racedvl69index.html
Woodstock,IL.northwest of Chicago
It's not what you buy, it's what you build!!
I did not climb to the top of the food chain, to become a vegetarian.
For some pics of my truck.
racedvl is offline   Reply With Quote
Old 04-12-2002, 10:58 PM   #17
imdarren
imdarren's Avatar
Post
busterwivell,
It seems to me that it would be much cheaper to fix the setup you have. Also, then it would be all original. Of course any parts dealer would suggest a new Vintage Air system. Just my opinion. Darren
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 04-13-2002, 12:01 AM   #18
Hutch
Hutch's Avatar
Post
You might check into Old Air:
http://www.oldairproducts.com/
They are out of Fort Worth Texas and have a system that will make use of the original
cab equipment with upgrades like sanden compressors, keeps the original look but updated.
Mine is not working but all I need is a compressor expansion valves and a charge.
Looking into the Sanden for a replacement on the compressor and going with one of the new R12 replacements for a charge.
John Hutchison
Grapevine,Texas
76051
71 1/2 ton swb 307 pg
69 Jaguar XK-E 4.2 Roadster
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 04-13-2002, 12:15 AM   #19
nroden
nroden's Avatar
Post
I remember riding in my brothers old 1950 Chevy Ton Truck Flatbed... of course no AC. It would get so hot in there sometimes.
Nick Rodenberg
Wellington, MO
White/Ochre/White
Nick Rodenberg
Old 04-13-2002, 11:35 AM   #20
wlee
Just an Old Mr Goodwrench
Post
Can you guys with AC tell me which side your alternator is on? My Non-AC '69 Longhorn has the alternator on the passenger side, and I'd like to convert it to an air cab . . . do I need to move my alternator to the driver's side, or can it stay where it is? Thanks! Lee
1969 Custom 20 Longhorn
1970 CST 20 Fleetside
1950 Plymouth Special Deluxe
1991 Jaguar Sovereign
1992 Mazda Miata
1969 Triumph Bonneville
1964 Harley Sportster
1969 CST 20 Longhorn
1992 Mazda Miata
wlee is offline   Reply With Quote
Old 04-13-2002, 11:36 AM   #21
RipMeyer
RipMeyer's Avatar
Post
Mine is on the driver side. You will prolly have to move it.
Old 04-13-2002, 08:01 PM   #22
Vince M
Vince M's Avatar
Post
SOON....I've got my whole air system out right now for a clean up and a conversion to 134a. Can't wait...
Orlando,FL
72 Chevy 4x4 3/4T CustomCamper w/SB 406
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 04-13-2002, 08:50 PM   #23
crew70
crew70's Avatar
Post
I think people didn't want to spend the money on the ac if it broke.so they would just take the compresser off if It was in the way.
70 chevy 3/4 ton 4x4 402ci crewcab
3/4ton
94 gmc 1 ton dually crewcab 454ci
99 suburban 5.7
2001 500cc ski-doo mxz
95 500cc ski doo fan
650 bombardiar 4 wheeler
crew70 is offline   Reply With Quote
Old 04-15-2002, 12:09 PM   #24
72LNGHRN
Post
Converted mine to R134a about three years ago havent had any problems with it yet.Already been using it about a month here in the desert.Keeps the cab cool even with all the air leaks in the cab.
72LONGHORN 350 CI TURBO 400 A/C P/S P/B HEAVY DUTY SPRINGS ALL THE BELLS AND WHISTLES.
TUCSON,AZ.
2001 DODGE RAM WIFES TRUCK
1961 OLDS DYNAMIC 88
394 2BBL UNDER CONST.
TUCSON,AZ.
2005 4X4 DODGE RAM 1500 "HEMI"LARAMIE 1961 OLDS DYNAMIC 88 394 4BBL UNDER CONST.
72LNGHRN is offline   Reply With Quote
Old 04-15-2002, 10:19 PM   #25
Cal69Chevy
Cal69Chevy's Avatar
Post
I do...'69 factory a/c
'69 Chevy, 4X4-SB 350 TBI-TH350 Trans-205 Transfer Case-Dana 44 Front-14 Bolt Rear-Front Disc Brakes-Factory A/C-P/S
Ken's '69 Page
Cal69Chevy is offline   Reply With Quote
