WTB: Automatic Conversion Parts, Steering Wheel, etc
I'm looking for a used Black factory steering wheel in good condition for my 72 Chevy Fleetside Truck. I would need everything since the truck at some point received a cheap aftermarket wheel.
The truck I just bought was originally an Automatic, but was converted to a manual some time ago. I'm not sure if it came with a Turbo 350 or Turbo 400 (K20, 4x4, 350 4bbl), but I'm trying to piece together the parts to switch it back to an automatic. I think I have the cross members already, but I need things like the brake pedal assmebly, shift linkage, column, indicator and any associated switches (position switch). I also need to locate a Turbo 350 or Turbo 400 that will bolt to the transfer case I have now. I need to do more research to determine what transfer case is in the truck. If you have any parts, please let me know. Thanks! |
![]() Join Date: Nov 2002
where are you located?
Chevy Nuttttt
the pedal assy should be fine if you remove the clutch pedal and it not original but i have a 70 something auto tilt i would sell for $50 plus ride. it is complete and is tight.
67' Chev swb step side 69' SS elky 03' Chev ext cab 4X4 hey who lernt me to spell ![]() ![]() |
Just like to part out trucks!!
I got AT linkages and crossmembers here is Ks. Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
Young Gun wth Fast Inline
I have a steering wheel. I'll PM you with more info.
JT
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
![]() Join Date: Apr 2000
just to let you know auto linkage is different between 4x4 and 2wd..
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
#8 | |
