Bad Thermostat?
I got the intake all done and fired it up tonight. Temp guage got to almost H then I shut it down. I checked the top radiator hose and it was still flexible like there was no water coming through. I filled up the radiator before I started it. Could it be a bad thermostat?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
You could have an air pocket under the t-stat (this can cause it not to open). I like to drill a small bleeder hole in them so this won't happen.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
Im going to change out the thermostat tonight. Where would you drill this hole on the thermostat?
see if this will do
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
~Rest In Peace~
for 4 bucks put a new one in
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
New superstant 180 in and problem solved. The other was was stuck. Not sure why. It wsa brand new.
![]() Join Date: Mar 2003
I went thru 4 t-stats. Then drilled a small hole in the first one.......It worked for me.
![]() ![]() Join Date: Jan 2005
I have a suspicion that if intake manifold gaskets are used that block the heat riser passages that run through the middle of the manifold, the thermostat has a hard time warming up when there isn't any coolant/water in the manifold yet. I've struggled with this issue many times. I like the idea of drilling a little hole in the thermostat.
