Old 06-11-2005, 03:34 PM   #1
Ogier
Chopper/Painter
Ogier's Avatar
Question Axle Ratio?
Greetings,
Any thoughts on what ratio the axle in my 77 1/2 ton might have? It is a corporate 12 bolt if that matters.
The engine/trans combo is 350/th350.
Thanks in advance,
With regards,
Ogier
1969 Chevrolet C20 - Resto-Custom started!!!
Ogier is offline   Reply With Quote
Old 06-11-2005, 03:53 PM   #2
Earl Filter
Earl Filter's Avatar
No SPID sticker in the glovebox door?
Real Name - Brandon
Current Vehicles:
1977 C20 Silverado 454/TH400 3.73s
1989 Jaguar XJ6 in the middle of an LT1/4L60E swap
Earl Filter is offline   Reply With Quote
Old 06-11-2005, 04:48 PM   #3
dswancutt
In typical GM fashion, Not all trucks have the axle ratio listed on the SPID sheet. Both of my 78 and my 79 6 cylinder have it, but my 79 diesel does not, and neither does my uncles 79 diesel. If fact, I don't believe either of his 79 six cylinders have it, nor does the 77 he owns. It is the first place to look, but you will probably end up pulling the rear cover if it doesn't.
Doug
dswancutt is offline   Reply With Quote
Old 06-11-2005, 04:56 PM   #4
Earl Filter
Doug
I've never seen a SPID without an axle code, even if it doesn't spell out the ratio for you. But, then again, I've never seen every GM vehicle, either! I know they do some weird stuff on a whim it seems.
Real Name - Brandon
Current Vehicles:
Old 06-11-2005, 05:14 PM   #5
dswancutt
The only thing I can think of is that it is only listed if you have an optional rear end ratio.
Both of my 78's have 3.73 and my 79 6 cylinder is a 3.40.
Doug
Old 06-11-2005, 08:48 PM   #6
TrainD5115
North Coast, baby!
TrainD5115's Avatar
You can try looking here. My sticker does not list a ratio either. http://67-72chevytrucks.com/vboard/s....php3?t=157669
Brad
79 Scottsdale C20
350/350
3.73's
Still running full CA smog gear!
TrainD5115 is offline   Reply With Quote
