Old 06-11-2005, 01:45 AM   #1
ramrod
tilt wheel
wanted to know wat year til colum will fit in my truck with little or no fab work its an1968 gmclwb 396 450hp turbo 400 stage 2 shift kit soon will have pics will be orange on bottom and black on top thanks for the help ive been reading posts for about 1year and it helped alot . also i have an 1985 truck will that colum fit thanks for the help
ramrod is offline   Reply With Quote
Old 06-11-2005, 02:07 AM   #2
dtlilly
dtlilly's Avatar
Welcome to the board from Wisconsin!
A tilt wheel from a 69-72 truck will be a direct replacement (plug and play).
Any tilt from a truck newer than 1972 will have the ignition key in the column, and have you running wild to convert wiring, etc. A van tilt is a popular conversion, but it will require cutting the output shaft and doing other types of custom engineering.
69-72 truck tilts will fit any 67-72 trucks. The automatic tilts run $200+, and manual shift tilts run $300+. Converted van tilts run $100+
dtlilly is offline   Reply With Quote
Old 06-12-2005, 02:23 AM   #3
ramrod
thanks for the reply i think i might try theone from the 1985 since i have one.
Old 06-12-2005, 05:19 AM   #4
71Dragtruck
71Dragtruck's Avatar
Seen it done on a 4-speed truck, he left the key in the dash and just used the signals. Also seen when guy's have cleaned up the key area filled and smoothed it.
71Dragtruck is offline   Reply With Quote
Old 06-12-2005, 08:12 AM   #5
70GMCer
70GMCer's Avatar
Would be alot easier if you found a Van tilt. I just installed mine without any cutting in my 70GMC. The one I used came from a 78 Chevy Van, with key in the dash. Only 2 mods you have to do. One is collapse the outer steering arm, that's the one connected to the steering box, and relocate the neutral safety switch. I bought a "Lokar" switch that mounts on my transmission pan. The following thread helped me......
http://67-72chevytrucks.com/vboard/s....php3?t=147927
Steve
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
