67-72 Addict!
Hey guys,
I got a 71' project truck with a 307. What kind of 4 barrell carb will bolt right on?. It has a 2 barrell now. I wanted to go to the junk yard and look around for a Q-Jet or similar. Thanks
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
There isn't any type of a 4barrell that will bolt on to a 2barrell intake without installing an adapter. They do make these rochester adapter plates but It would be much more effective to just install a new intake.
Pick up a 4barrell intake but be leary of buy carbs from junkyards. If the thing sits too long it oxydizes the fuel and ruins the carb. |
67-72 Addict!
Zkast,
You're right about the intake. My project truck looks like yours!. Nice pics you got there. I wish the motor looked like yours!
Old Skool Club
![]() Join Date: Jun 2001
Not that this helps, but I gave away my 4-bbl intake a few months ago, after installing an Edelbrock Performer. I have an Edelbrock 1405 (manual choke) square-bore carb that I pulled off and replaced with an Edelbrock 1901 (I think this is the right number) Q-Jet. I love it and I recommend it. Do what you have to do, tho.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
![]() Join Date: Jul 2000
Holley makes a 500cfm 2-barrel that will bolt on to your manifold. Also, I think the big American iron, like Olds, Buick, and Pontiac, used large two barrel Rochesters.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#6 | |
Bloo
if you need it, ive got a factory 4 barrel (q-jet) aluminum intake ill sell, only thing is it has EGR so youll have to get a block off plate
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
"See the U.S.A....."
Yea, you can get a block off plate or do like the previous owner of my truck did and fill the hole full of J-B Weld! Some people???
1970 short bed fleetside 1949 all origional chevy 3600 1974 camaro Richmond , Texas(just S.W.of Houston) |
