![]() Join Date: Feb 2001
Dwell setting???
What's the best way to set the dwell in the points when you don't have a dwell meter? Can you adjust it while its running and listen for anything? Thanks for any help.
Joshua |
Years ago, and I mean many years ago, I used to adjust the point gap with a piece of matchbook cover. That was before I was able to buy a dwell meter. That always worked for me.
1997 GMC Sierra Ext 1965 Mustang |
with the cap off bump the motor over to get it so the points ramp is on the highest point ov the dizzy cam and use a feeler gauge to set the points at .019" if they're new p[oints or .016"gap if the points are used
#4 | |
![]() Join Date: Apr 2004
![]() Quote:
1968 Chevy 4x4 307 4 speed |
#5 | |
Out draggin'
Exactly... The matchbook method works in a pinch too ![]()
91 GMC Xcab LB-Bags/bd/caddy clip SOLD 72 C10 Cheyenne Super LWB SOLD 92 GMC K1500 Burb 72 C10 Burb (ex. Cheesewagon)SOLD 72 C20 Burb parts truck 71 C10 Burb "project" |
Saving 1 truck at a time!
Don't forget to reset your timing after setting the dwell since it affects the timing. I know you probably already know this but just thought I would mention it.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
#7 | |
member #16
![]() Join Date: Dec 1999
Another method that has been around for years, is to adjust while running you turn the adj. screw in until it starts to misfire and then back it out 1/2 turn. You can check with dwell meter and it will be about 30 degrees dwell. John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
#8 | |
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
