Keep On Truckin'
Anyone drill and tap the differential (12 bolt) for a drain plug? If so, what size and location? Thanks
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... Last edited by mocwon; 06-15-2005 at 09:31 PM. |
'67 K10 Work In Process
Most diff drains I have seen are in the cover. They usually consist of a fitting that goes thru a hole you drill in the cover which has internal threads for the plug and seals on each side to prevent leaks. You should be able to buy a drain plug kit from an area auto parts store. Not the best description but I hope this helps.
Ya just put it on the cover, you can get a kit like mjrmn said, or weld on a threaded collor, drill a hole in it, and install a plug. If you feel like spending money LPW's Ultimate-12 cover has a fill and a drain.
Keep On Truckin'
Thanks!
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
