Advanced timing??
My 350 is running at 12 degrees right now. I was just wondering if I could go further or not. If so how do I know when to stop, I should get some spark knock or something uhh?
'68 C-20 396 CST CC
![]() Join Date: Mar 2005
I'm assuming you have an HEI?
Well, it's a by-ear thing. When the timing is really advanced you'll have the best idle but early pinging (detonation, spark-knock) will occur-usually under load as soon as you drive it. The trick is to find out what kind of timing allows for a smooth ide with NO detonation. There are more scientific measures to adjust your vaccuum advance unit on the HEI distributor to match the application (street/strip, towing, heavy mileage), but unless you're application is "bread-winner" I don't think we need that kind of attention. Good luck!
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES ![]() 01 Jetta Turbo Daily Driver ![]() 84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico ![]() |
Mike
If you get to much timing you will get some pinging,and it can give you hard starts when the engine is hot.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
