![]() Join Date: Aug 2002
tail gate
Any ideas on how to keep my tail gate from making so much noise when im driving it? It seems to be pretty tight.
Are the rubber bumpers still present and accounted for? You could also get some thich rubber sheet and cut some small squares and glue them on over the contact areas.
No No
Like mentioned above check all the rubber stops. Also you can take the rods out of the inside since they like to jiggle around and make noise and put some of the apropriate size vacuum/fuel line over the rods in a few choice spots.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
Waiting for Paul to Open Safe
re:tailgate
Not sure what year your truck is, but I have found that sometimes the metal hinges which hold your tailgate when it's open have a tendency to bang around when the tailgate is closed. I put a little weatherstripping in the channel where they hang while they are closed and it helped a lot.
Its a 79, Thanks for all the helpful info. I'll try some and let you know how it works.
Jason |
