06-19-2005, 05:36 PM | #1 |
OK...Here's a new one
A friend of mine noticed that my right side tail light/brake
light goes out when I press the brake pedal. Both the tail light and the brake light (both filaments) turn off. This only happens when the light switch is on and the brake pedal is pressed. Is the brake light switch (under the dash) the culprit?...or possibly the headlight switch is causing this?...or is this more complicated? Anybody else have this problem? Thanks! Jim Mt Juliet |
06-19-2005, 05:51 PM | #2 |
I also discovered that after taking off the lenses...that
he right side tail light is not as bright as the left side... go figure. Jim |
06-19-2005, 05:55 PM | #3 |
Checked the grounds yet ? That would be you dim bright problem for sure. Fix that and you may have corrected the light's turning off when you use the brake.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
06-19-2005, 06:14 PM | #4 |
68 C/10
sounds like a ground problem to me.
(2009) GMC Sierra Denali 6.2 AWD (67 C/10 fleetside SWB) (2018GMC Yukon Denali) Wifes Car |
06-19-2005, 06:20 PM | #5 |
if it's not the ground today, it will be some day. Clean 'em up cause bad grounds can cause all kinds of greif
I got a bench seat baby, you don't have to sit over there. |
06-19-2005, 06:45 PM | #6 |
a definte wortwhile project is to clean(shiney metal on shiney metal) your grounds and it doesn't hurt to coat them with dielectic grease while you're at it
06-19-2005, 08:08 PM | #7 |
I did check the ground on the taillight fixture and it looks good. So the taillight is grounded to the bed and the bed is
bolted to the frame. The negative side of the battery is connected to a bolt in the exhaust header. So it seems to me that the ground circuit should be completed. Do you guys have ground straps that connect the bed to the cab and etc? Jim Mt Juliet |
06-19-2005, 08:47 PM | #8 |
There should be two grounding straps at the rear of the engine that attach the engine to the cab. There should be a grounding strap that connects the cab to the chassis, down on the front passenger side cab mount. There should be a grounding strap that connects the passenger side inner fender to the chassis, up under the battery. There should be star washers at each end of each grounding strap between the grounding strap and the metal it is attached to.
I don't think there is anything wrong with your brake switch, because otherwise nothing would turn off when pressing the brake. |
06-19-2005, 09:27 PM | #9 |
The two tail lamps are connected to the same voltage source (brown wires), so if one tail lamp is on and the other tail lamp is not on, then it seems like there must be a grounding issue.
06-19-2005, 10:51 PM | #10 | |
C10 Junkie
09 Chevrolet HHR --- Cruck --- cross between a Car and a Truck Former rides: 1967 C10 LWB 1972 C10 LWB 1969 C10 LWB (parts truck) Last edited by armyavncowgirl; 06-19-2005 at 10:53 PM. |
06-19-2005, 11:32 PM | #11 | |
06-20-2005, 12:03 AM | #12 |
its all about the +6 inches
As for the brake light going off...chainge the bulb.
06-20-2005, 12:21 AM | #13 |
I did change the bulb with a known good bulb...no diference. I also ran a separate
ground wire from the taillight fixture to bare metal on the cab...no difference. I think I'll check out the connections at the taillight fixture in the morning to see if something is not making good connection. I might as well check the connector at the tail light harness while I'm under there. Thanks for all the good suggestions! Jim Mt Juliet |
06-20-2005, 12:32 AM | #14 |
does that turn signal work in back?
06-20-2005, 02:10 PM | #15 |
Problem solved.
I ran a long wire directly from the tail light fixture to the battery negative terminal to try and eliminate the possibility of a bad ground. No change...light still goes out when the brake pedal was pressed. I got the voltmeter out and checked both contacts...12v on the tail light contact and 12v on the brake light contact. So... I wiggled the bulb and sure enough the tail light brightened up and it also stays on when the brake light is pressed. So...for the 3rd time I pulled the assembly out and tried to clean the barrel of the light fixture. No luck...but that has to be the problem. So I took a pair of vise grips and slight warped the barrel. bulb fits sort of tight... but it now makes good contact. Since I'll probably replace both tail light fixtures anyway...I guess there's no harm done...and it works! Jim Mt Juliet |
