06-19-2005, 05:41 PM | #1 |
Key on power Where ?
I dont have the battery hooked up yet and I was wondering if anyone knew off hand what wire would be a key on power source form the ingition switch of fuse box. I to find it so I can hook up my fan and tempature gauge.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
06-20-2005, 05:25 PM | #2 |
ttt
06-20-2005, 06:31 PM | #3 |
Cause the Chicks DIG IT!!
Theres an open spade on the fusebox that has ign over the top of it. That is a keyed hot feed. That is where I had my electric fan hooked up at first until I put it straight to the battery and hooked it up to a toggle switch
06-20-2005, 06:57 PM | #4 |
Oky so that would be a key on power. That's what I need. I would hook up the battery but when I do that I want to start the truck. This way when I get the fan and temp gauge wired up I can jump in and break in the motor.
I got the painless kit that comes on at 185 off at 170. I needed a power all the time I got that from the little block that used to be mounted on the inner fender and I needed a key on power. I took the black wire that went from the relay to the switch in the cyl head and I added a toggle switch that goes to ground. That way I can turn the fan on when I need it or it the switch goes faulty. It also would be handy if someone else takes it out the switch in the head will take care of cooloing dutys.
06-20-2005, 10:09 PM | #5 |
thats pretty much a similar set up that i had. I had the relay in there that kicked the fan on and off automatically. I put the toggle switch in there so I could shut the fan off when parked so it wouldn't drain the battery if i was worried about it.
