06-22-2005, 04:12 PM | #1 |
Widening wheel tubs for bigger tires?
I know this has been asked before but seeing how the search is down i am looking for some help. Can someone shed some light on this subject. I have seen posts before with pics. Does anyone have a link to any posts on this subject?
Thanks a bunch Ron.
1968 Chevy C10 Short Fleetside/Wood floor ECE 4-6 Drop / 406 Small Block 1971 Chevelle 427 Big Block |
06-23-2005, 09:26 AM | #2 |
Anyone?
06-23-2005, 10:03 AM | #3 |
67 is sold
Sounds like you want to 'mini-tub' the truck
I don't have any links or pics. |
06-23-2005, 10:06 AM | #4 |
I used galvinized sheet metal down the sides and rounded pieces over the wheels.
tack welds and rivets.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
06-23-2005, 10:36 AM | #5 |
fugedaboutit
I want to do mine too. Was thinking of cutting them down the middle.. adding about 3" of material.. cutting bed floor to fit.. drill new holes and re-install. Be aware of where bolts are running along the frame... I think if you cut too much out- those bolts will be a PITA to get back in (your new tub will be directly over the frame.) Oooh.. just noticed you got a wood floor.. might be more difficult.
Currently truckless |
06-23-2005, 11:48 AM | #6 |
Just go the junkyard and buy some wheel tubs from another truck and use then as donor metal.
https://www.ebay.com/itm/295742064443 |
06-23-2005, 11:49 AM | #7 |
Yep, looking to do a mini tub. I was also thinking of getting another set of tubs and cutting 3-4 inches out of the center section. This would look more like the factory appearance. I have seen one thread before with this done but can't find it with the search down. I think boardmember Purs was also going to do this.
06-23-2005, 11:54 AM | #8 |
I am looking for the old post as well. There was a good one out here not long ago; explained how much to cut out of the bed, how much to add to the wheel well, etc.etc. A really good post, that when found could be added to the stickies for mini tubbing.
Keith 70 CST longbed in progress. Hoping to get it back on the road soon. |
06-23-2005, 12:43 PM | #9 |
Yep, I hope someone has it.
06-23-2005, 01:04 PM | #10 |
Just Don't Stop!
these...
1968 C10 build in process TT LSA/6L90e/9" |
06-23-2005, 01:12 PM | #11 |
FirstGen-
Yes, it was from that post I believe. This was one of the trucks I remember. Thanks Do you have that post saved by chance?
06-23-2005, 01:21 PM | #12 |
I don't have the link, but here's another pic for you. I think if I were doing it, I would find some donor tubs, cut yours on one side, cut the donors on the other side, resulting in only one seem, or weld to fill.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
06-23-2005, 02:05 PM | #13 | |
06-23-2005, 03:34 PM | #14 |
Ill throw one in...
1972 C10 SWB 350 / T400 1972 SWB GMC 350/T350 1972 Cheyenne 20 super "long horn". 402BB / T400 1972 Suburban C10 Deluxe 350 / T350 and a few more.. http://www.myspace.com/afew72s |
06-23-2005, 05:44 PM | #15 | |
As the other members said, use tubs from a junkyard or where ever. I will just use number so don't think the are correct measurements. If the original tub is 18" and you want to make 24" tubs. Take two left tubs and cut one 12" from the driverside and cut the other driverside tub 12" from the right. Weld them together and you have a 24" driverside tub. Do the same for the passengerside tub. If you are really good you will overlap the center piece for strength. I won't attempt to explain that.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
06-24-2005, 09:31 PM | #16 |
How big of a tire could I fit if I mini tubed my 70? Anybody got some picture of the tires on a mini tubed truck?
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
06-24-2005, 11:31 PM | #17 |
I have a nice set of wheel housings that have already been increased in width. I plan to sell them in the next couple of weeks. If you are interested I can send you some pics along with measurements after the 4th of July.
06-25-2005, 12:12 AM | #18 | ||
Stock fleet tubs are 11.5" @ their widest point (from the bed wall to the mounting flange) & only 8.5" @ the point where the tub starts to form the 'crown' or the rolled edge. If you splice 2 together, you have to cut them where they're still 'flat' or approx 8" from the flange that bolts to the bedside. This means about 18~19" max width when splicing 2 together. As you can see in the first few pics, those tubs are 21" wide which is why there are 2 seams. The stock tubs were split & a flanged 9~10" piece of metal was added. They can also be bolted in just like factory because the bed floor was also kicked up for pumpkin clearance. Quote:
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-25-2005 at 12:28 AM. |
06-25-2005, 02:39 AM | #19 | |
You are so correct. Who made the flanged strips? They ought to think about selling the strips or tubs made to order.
How much did you narrow the rearend to fit the wheels and tires? Quote:
06-25-2005, 12:56 PM | #20 | |
The rear end wasn't narrowed. It was a stock length 67-68 12 bolt coil rear. I used custom widened steelies. I didn't narrow it because I knew in time the larger diameter wheel/tires I desired would be available. This was done many years ago as I've be messing w/this thing for almost 20yrs . No frame mods other than removal of the factory bumpstop. This was done w/just widened tubs & widened wheels w/the proper backspacing. No pics as the wheels/tires are long gone & replaced w/some 20's (which have also been replaced ).
06-25-2005, 05:28 PM | #21 | |
Your UncleBen
thanks CHRIS
68 C10 shortbed -- Street/Strip |
06-25-2005, 11:39 PM | #22 | |
06-26-2005, 12:22 AM | #23 |
tubs
OOOPPSSS! Sorry wrong year!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 12-12-2005 at 12:47 PM. |
