06-26-2005, 12:38 AM | #1 |
How to remove a grille?
I have a 62' Chevy and the PO put the wrong grille on, anyhow I cannot figure out how to take it off? I looked around by the radiator don't see the bolts, looked inside of the fenders, dont see them...... can anyone help me please?
I know this sounds so stupid and easy but I am stumped. Thanks in advance.
________________________ 62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4 08' Chevrolet Silverado CrewCab 05'Toyota Tacoma Prerunner SR5 |
06-26-2005, 05:41 PM | #2 |
Look inside the fender wells and on the grille support panel, which is what the grille is mounted on. There should be 4 bolts on each side that attach the grille. There should be 2 bolts on each side of the outer side of the grille and 2 just inside from the bezels.
06-27-2005, 10:01 AM | #3 | |
I will check again thanks for the help Any pic's?
06-28-2005, 05:28 AM | #4 |
THERE IS NO NEED TO PULL THE BEZELS AS ALL THE BOLTS YOU NEED TO TAKE OFF ARE BEHIND THE GRILL SUPPORT LIKE 65stepside EXPLAINED............DON'T FORGET TO DISCONNECT THE WIRES FOR THE HEADLIGHTS..................IT WOULDN'T HURT TO HAVE SOMEONE HOLD THE GRILL WHEN YOU TAKE THE LAST OF THE BOLTS OUT....................HEMMIT
