ureckmefixit2@cox.net
Yes I do. The rod from the latch angles to the inside of the truck when installed right. The bottom of the rod allways gets stuck in the latch if you put it in angled to handle. With handle off put both rods from latch into the latch. Take 2 of the 3 latch bolts out. put key in the lock, install both rods. take #3 bolt from latch ( dont drop latch ) lower latch and turn key and install handle and lift the latch and put bolts back in. Make sure the rod dont come out of the latch. You dont have to take the trim panel off. You can go in thru the vent in the door jam but its tricky. Matt typ'n w/1 finger
That's U RECK ME FIX it 2 74 Chevy Short Bed 355ci Sportsman II 64cc Angle Plug Crower Custom Grind .462in .486ex Dyno Test 422hp @ 5600 And it's got a Holley 3.73 Gears 12 Bolt 3.73 w/Posi 700R4 Going In I'm a Body Man So There! That's why it's not painted |
| Bookmarks |
