06-28-2005, 05:42 PM | #1 |
How to plumb a hydraulic brake booster?
I got a hydraulic brake booster from a late model Chevy with a 6.2 to use on my Cummins powered C-20...................However, I am not quite sure how to plumb it up. Anyone know how to run the plumbing or better yet, have a diagram or picture?
Thanks TP(Tyler)
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
06-29-2005, 09:11 AM | #2 |
NOBODY here is running a 6.2????????? Man, I know they are bad, but I didn't think they were that bad
TTT(Maybe, possibly)
06-29-2005, 12:51 PM | #3 |
I am using a system off of a 1989 1 ton with a 454. I don't know if this will help, but here goes.
A high pressure hose goes from the powersteering gearbox #1 to #8 on the hydroboost brake master. A low pressure hose goes from the powersteering gearbox #2 to a powersteering cooler then to the low pressure side of the power steering pump #3. Another low pressure hose goes from the powersteering pump #5 to #7 on the hydroboost brake master. Lastly a hose goes from #6 on the hydroboost brake master to the powersteering pump #4. I think this is a hypressure hose, but I can't tell from the attached pic or from my memory. PM me if you want me to double check as I could not find my original notes to make sure the above is correct for the #4 and #5 connections. Hydroboost master powersteering gear box powersteering pump
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 06-29-2005 at 12:52 PM. |
