Old 06-29-2005, 10:03 AM   #1
edman87
junk collector
axle width?
How much wider is a d60 dually front than a srw d60 front? What about the difference between a d70 dually rear and a 14ff single rear? I would guess 4 inches each side, but not sure. Anybody knowing the hub to hub width of these common axles, please post them.
'87/89/76 K5 in progress
'99 K2500 short crew
'91 camaro rs
'98 jeep tj
'52 willys cj3a
edman87 is offline   Reply With Quote
Old 06-29-2005, 10:35 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I believe on the fronts about 8" overall or 4" per side, dually rims typically have 7" of backspacing. I'll look for the dimensions.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 06-29-2005, 11:40 AM   #3
ryan68
Certified Chevy Man
ryan68's Avatar
Front 60's are about 69-70" wide WMS to WMS. Most dually front axles just have a 4-4 1/2" hub spacer bolted to the axle which can be discarded.
68 Chevy CST (327,TH400) 3/5 drop lots of fun stuff
71 Suburban 4x4 (350,TH350) 7" lift 37's, D44/14 bolt and other sorts of goodies, lockers front and rear, flexes 40", 895 RTI score
Check out my web site!!! http://www.geocities.com/cst68chevy/
ryan68 is offline   Reply With Quote
Old 06-30-2005, 11:47 AM   #4
1969 GMC
1969 GMC's Avatar
IIRC, the D70HD is 75" wms-wms and the 14 bolt is 67".
One thing to point out about the DRW D60 front axle- most people do discard the DRW hub bodies, but SRW replacements aren't cheap. Expect to pay at least another $400 for them.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 06-30-2005, 01:52 PM   #5
Americanrider
Convert a DRW Dana 60 Front to SWR
http://67-72chevytrucks.com/vboard/s....php3?t=161475
Americanrider is offline   Reply With Quote
