Old 04-16-2002, 07:50 PM   #4
Cheyenne Super
Post
What do you think about this. fab up some custom mounts that attach with the rear axle. Attach your end link to this bracket. Then make a mini cross member or use an existing one if it is close enough and attach the swaybar clamps to that cross member. Here is something else to consider when I called classic performance today. they told me that thier coil over kit by itself handled better than the best coil spring/shock/sway bar setup. Another sorta off the wall idea is to use a stock car style setup which uses endlinks that push arms attached to a bar of spring steel.
What do ya think?
1971 Cheyenne Super
Soon to be converted to '68 front clip.
Efland, NC
Cheyenne Super is offline   Reply With Quote
