Old 07-04-2005, 02:34 AM   #1
kevncar
Active Member
kevncar's Avatar
Shimming a starter
Trying to help a friend get the starter on a blazer he just bought working right. The previous owner had problems with the starter engaging and said he had even spent over 500 dollars at a shop getting a new flexplate and starter put on it. 2 months later it didn't work again.My friend just finished putting a new starter in it and brought it over and it will start but it makes a nasty grinding noise as it does. Thought I'd ask the wealth on knowledge here to help us get the thing shimmed right, or whatever it's gonna take. Thanks in advance.
Kevin
72 Chevelle
67 C10...454/TH400
Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961
kevncar is offline   Reply With Quote
Old 07-04-2005, 07:49 AM   #2
68C15
blood type; Retumbo
68C15's Avatar
many "reman" starters have the nose cone machined. I would suggest hitting the dealer for a new nosecone. these shouldnt have any shims at all. I used to have a wire guage for setting the distance between the starter shaft & flywheel. I dont remember the distance so I will have to try to find it.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 07-04-2005, 08:40 AM   #3
cdowns
cdowns's Avatar
if it's makin noise the first thing to do is to check the flexplate for rounded off teeth ,it doesn't take long to trash a flexplate
i like the hi=torque ministarters they're easy to install and most have lots of adjustments built in
Old 07-04-2005, 10:03 AM   #4
Billy G
Billy G's Avatar
I had this problem on my 76 Chev years back. What we ended up doing was getting a NEW nose cone....Using a paper clip as the "mesh" gap....milled the nose cone by file until it fit. Haven't had a problem since. That was in '92. Just remind my sons that if starter goes out...KEEP the nose cone. Hope this helps.
Seems as if it was in a "Chilton's Manual" I read that was the difference. I know it's NOT much gap.
Billy G
My FAMOUS LAST WORDS...."Ima Gonna!!"
- 1970 GMC 1500 swb/step 250 I-6 3 spd - "The GEM"
- 1976 Chev Scotsdale swb/step 350/350 - "The JEWEL"
- 1982 Chev C-10 swb/step 250 I-6 3 spd -
- 2001 Chev Silverado LT -
Last edited by Billy G; 07-04-2005 at 10:05 AM. Reason: Paper clip as 'feeler gauge'
Billy G is offline   Reply With Quote
Old 07-04-2005, 10:34 AM   #5
2low72
I had a problem a while ago, found out I needed to stop buying starters from autozone. I spent a little extra on a mini stater and haven't had a problem since!
2014 GMC Yukon XL (Wifey's)
2004 Chevy Silverado Crew Cab Z71
2low72 is offline   Reply With Quote
Old 07-04-2005, 12:22 PM   #6
A.P.
Black 72 Chevy
A.P.'s Avatar
When I replaced the starter and flexplate on my truck, I used no shims at first. With no shims my starter would make a really bad grinding noise. Shim it and start with the thinest.
A.P. is offline   Reply With Quote
Old 07-04-2005, 01:13 PM   #7
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
grind the nose off of mine to after shimming didnt take it out
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-04-2005, 01:21 PM   #8
krue
Designated A-hole!
krue's Avatar
I had the same problem and shimming it wouldn't fix it. Went to a local auto electric shop and he sold me a nosecone that fixed my problems.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 07-04-2005, 02:06 PM   #9
cowboy33713
Howdy:
where is a good source for shims? Have a bit of a problem with my 67, but not severe. Most parts counter people here don't know what I'm talking about, and not having any shims to show them (never needed any before), I can't get across to them what they are, or what them look like.
cowboy33713 is offline   Reply With Quote
Old 07-04-2005, 02:14 PM   #10
LONGHAIR
Usually there is a "HELP!" rack at the bigger autoparts stores........they should have shims there.
I always keep the old housing though. Sure it's more work, swapping ends, but you know it will fit then.
LONGHAIR is offline   Reply With Quote
Old 07-04-2005, 02:20 PM   #11
cowboy33713
Howdy;
thanks again, Longhair. Saving a properly fitted nose is the hot tip , but this one was noisey when I bought this truck. Have been taking care of a bunch of other things first so starting on a regular basis hasn't been a huge consideration yet, but will be soon.
cowboy33713
Old 07-04-2005, 03:57 PM   #12
tomatocity
tomatocity's Avatar
Better yet take the starter to an Auto Electric sshop and have them rebuild it. There is a very good auto electric shop in Sacramento and I take all of my starters and alternators to them. Three years ago I road my bicycle in the rain to deliever the starter off my S10 4.3L (PIA to remove and install). They were gracious enough to build it in two hours while I went for coffee. Substantial tip offered though not accepted. The rain quit after I got home, go figure Tim
Originally Posted by Billy G
I had this problem on my 76 Chev years back. What we ended up doing was getting a NEW nose cone....Using a paper clip as the "mesh" gap....milled the nose cone by file until it fit. Haven't had a problem since. That was in '92. Just remind my sons that if starter goes out...KEEP the nose cone. Hope this helps. Billy G
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 07-04-2005, 06:34 PM   #13
chevyhouse
BEER-Vacation in a can...
chevyhouse's Avatar
Shims won't fix this one....you are to far away from the flexplate with the conditions you are discribing (go ahead, ask me how I know) you either need to get the nosecone milled or better yet, shop around for a "80 thousands" starter-a Gm starter that is already milled .080 I called the manufacture, Westling starter, westling.com and they hooked me up with the part number and a local distributor and after 2yr of the same crap your friend is going through it was fixed. my part number was 729106s-080 for a 350. good luck
Kurt
03' Trailblazer
69' C10 "SPSHL-K", 388 stroker/BTO 700R4, 2400 stall, 3.73 posi, lwb, fleetside long box, 3.5"/5" drop, 18" Budnik
2000 Yamaha V-Star 1100 Custom
For Sale-87' V10-4x4, 408/700r4, 4.10's PM for pics
chevyhouse is offline   Reply With Quote
Old 07-04-2005, 07:14 PM   #14
jamie72
jamie72's Avatar
hey krue how much was the new nose cone???
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 07-05-2005, 12:21 AM   #15
krue
Designated A-hole!
krue's Avatar
I think it was thirty or forty bucks. I heard someone on here got one a lot cheaper. It uses the two bolts holes straight across instead of the diagonal holes. Gets it a few thousandths closer to the flywheel. I put it on a new starter and kept the new starter's nosecone to put back on when/if I have to replace it under warranty.
www.daveramsey.com
