air bags
How hard is installing an air spring set up in a 67 chevy truck? It seems easy as the air bags replace the coils, but just wondering if anyone has tried it, and the pros and cons of installing this. This truck will never haul anything so dont have to worry about that.
67 chevy stepside, 6 cylinder, three on the tree, small window. Currently in resto. |
More Cowbell....
If your truck already has coils/trailing arms in the rear, then our trucks are in the list of 'easier-to-do' trucks. The rear ones bolt right in place of the coils and the fronts just require a mounting plate. You can get as fancy as you like, but it is pretty straight-forward.
You might want to consider a longer track bar.....like the SuperTrac.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 07-07-2005 at 04:41 PM. |
![]() Join Date: Apr 2005
Couple of links:
http://67-72chevytrucks.com/vboard/s....php3?t=152897 http://67-72chevytrucks.com/vboard/s....php3?t=129463 Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Thanks those articles helped, I think I may try installing them
