![]() Join Date: Jul 2004
Put gas tank over carpet or not ??
I have new full length carpet for my '68. The gas tank has the thick tar paper shims under it. I would like to sit the tank on the carpet and eliminate the shims, but that will also space the tank mounting bolts away from the cab. Should I trim the carpet, so the tank sits on the carpet on bottom, but cut front side so tank can bolt straight to bab without carpet in between ? There is not much room between cab and tank and don't want tank to hit seat or does 1/4 inch matter ?
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
Gonna put er in tommorow afternoon, any thoughts ? Thanks
Seņor Member
I'd notch the carpet. Too much work taking the tank loose just for what you're suggesting.
carpet retaining moisture will cause rust on the tank bottom
