Old 07-10-2005, 11:59 AM   #1
Ballard Viking
NV 4500 tranny swap
Hey, anybody ever done this? It seems like a good idea. I have a 456 rear end spinning 35s. The bigger tires helped some but I still need an overdrive. I've heard that the dodge version of this tranny might work better because of linkage location. Also I think its a hydraulic clutch. How do you approach that?
72 GMC 3/4 ton 4wd- Col. Mustard
94 Kenworth/MTM concrete mixer
Ballard Viking is offline   Reply With Quote
Old 07-10-2005, 06:22 PM   #2
Americanrider
I'll be doing one next year but using a 94 GM 4x4 NV tranny, it's a better match for the transfer setup I'm planning. The is a thread in the FAQ section that covers this. Also been hearing/reading bad things about Dodge's 5th gear problem. Are you runnig a 4x4 too?
Americanrider is offline   Reply With Quote
Old 07-10-2005, 06:29 PM   #3
TP from Cntl PA
TP from Cntl PA's Avatar
When you lug down a 360 Cube Straight 6 Cummins going up a hill in OD with 12k in tow your bound to have tranny troubles.........They should have a Roadranger behind that engine, not something for a light truck.........
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 07-11-2005, 08:31 AM   #4
Ballard Viking
Yeah Boone, I'll keep the np205. I just want something to drive up to the mountains in the winter- without screaming at 50mph. How are you getting your tranny? Junkyard? and how much?
I'll check out the FAQ. Thanks.
Old 07-11-2005, 12:48 PM   #5
Americanrider
I found one in a remote junkyard in South-western Idaho for 750. Best place is the small farm towns where they don't do much 4x4-ing Here is another place to look for one:
http://www.car-part.com/
The Bellhouse from Advanced adapters and the tranny-transfer adapter are going to be costly but I figure they will be worth it in the long run. Lower RPM, less engine strain and better gas mileage. I drive a 5sp Jeep Rubicon most of the time, but in my truck I'm always wanting that next gear.
http://www.off-road.com/products/sho...adapt-show.htm
I'm building on a budget, this years mods are power steering and disk front 44 with power brakes.
The member that built the setup that went into ryanroo's truck is "kwmech"
