07-10-2005, 06:09 PM | #1 |
Tach Problem
Scored a Tach dash,but as usual have a problem. Hooked it all up and tach goes to 500 rpm and stays. checked to make sure it wasnt binding,still only 500.Checked connections and still only 500! Any ideas or should i just start over?
72 chevy C-10 swb fleetside,402 BB.700r4,buckets,console.etc. 72 Blazer CST 350,AT, new project 1971 Chevy Nova ,355 SB blow through turbo in works. |
07-10-2005, 07:31 PM | #2 |
hei or stock points inginition?????
07-10-2005, 10:46 PM | #3 |
HEI ,,connected the coil wire from tach ,to tach spade on distrubitor
07-10-2005, 11:25 PM | #4 |
its all about the +6 inches
Check your ground from insterment panel to the dash. Most likely it is a bum tach though.
07-11-2005, 07:35 AM | #5 |
ttt
07-11-2005, 11:26 PM | #6 |
Just here to help
Where does the ground hook to?I am having the same trouble here also.Tach goes to about 700 and will move up and down but wont go up any farther.Ground or junk tach?
