Old 07-12-2005, 10:36 PM   #1
frost89434
frost89434's Avatar
Brake line needed.
I am in need of the brake line on the rear passenger side axle. I have a 10 bolt coil rear 2wd. Where it goes into the tee it is 1/4" I believe. the other end goes into the brake drum housing. all I need is the short line. Any help would be great!!! Thanks JIM
68 short fleet with 71 front clip 2wd jaguar blue
99 chevy ext cab shrtbed z71 loaded
99 chevy swb fleetside(daily driver)
Sparks, Nevada
frost89434 is offline   Reply With Quote
Old 07-12-2005, 11:36 PM   #2
thejoker
thejoker's Avatar
If you can give me to at least the weekend I might be able too help. I will need to look and make sure the one I have is in good condition.
If you don't hear back by Saturday drop me an email. thejoker(at)gatewayriders(dot)org .
thejoker is offline   Reply With Quote
Old 07-12-2005, 11:40 PM   #3
frost89434
frost89434's Avatar
No problem!! Thanks
Sparks, Nevada
Old 07-12-2005, 11:54 PM   #4
68haywagon
I'm watching you!
If that doesn't work out you can pick up a piece at your local auto parts store pretty cheap. Just bend it by hand into shape.
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 07-13-2005, 12:16 AM   #5
frost89434
frost89434's Avatar
Mike
I tried that. The problem I am having is that the ends are two different sizes. The T is 1/4" an where it goes into the drum I think it is 3/16ths.
Sparks, Nevada
Old 07-13-2005, 12:24 AM   #6
68haywagon
I'm watching you!
Hmmm weird. OK just a thought. Good luck on your adventure.
Mike
Old 07-13-2005, 07:03 AM   #7
MOTHERTRUCKERS
Somethings weird most all drum brakes use 1/4 line, did you get a 3/16 fitting to screw into it? Are you sure the wheel cylinder has not been replaced with a newer metric cylinder by mistake? 1/4 x 3/16 adapters are available from NAPA it is the same adapter used when putting a disc brake front end on a drum brake truck. What year is your truck with a 10 bolt rear?
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 07-13-2005, 09:17 AM   #8
frost89434
frost89434's Avatar
The truck is a 71. I checked this morning and It is a 3/16th on the drum. I am going to napa today to try and find an adaptor.
Sparks, Nevada
