Old 07-13-2005, 09:34 AM   #1
FUNMUDDER
FUNMUDDER's Avatar
Talking Any difference between 1/2 and 3/4 ton frames?
Are there any differences between the 1/2 and 3/4 frames, like strength wise, and will 3/4 ton axles bolt up to a half ton frame? If I can put 3/4 axles under it, will i be as strong as a 3/4 ton? The reason I'm asking is because..........................................................................................
I MAY HAVE GOTTEN LEEDS ON A COMPLETE 69-70 1/2 TON 4x4 TRUCK WITH A GOOD FRAME AND CAB FOR FREE!!!!!! The guy used it to plow his driveway and he gave it away to another guy. BUT, the guy he gave it to shot himself, so now this little old lady has it on her property, and she might give it back away since it was given to her, and to get it out of her sight. It has a 292 in it with a four speed, complete 7' plow and plow rigging (the guy said i could have the plow, because it is at his house).
But i was just curious if the frames were different because i wanted to put 3/4 axles under it if the truck was any good. Or it may just be a freebee parts machine. who knows. but a free chevy pick-up sounds good to me, running or not!
FUNMUDDER is offline   Reply With Quote
Old 07-13-2005, 09:55 AM   #2
Mudder
Mudder's Avatar
I believe the frames are basically the same. You will have to move the spring pads on the rears unless its a 73-up axle.
Mudder is offline   Reply With Quote
Old 07-13-2005, 10:47 AM   #3
Blue_71
Bloo
Blue_71's Avatar
the 1/2 ton frames are visably thinner when you cut a section out of both and put them up together. i put 1/2 ton frame horns on my k20 and before it was welded up you could tell they were smaller, the vise grips wasnt holding the frame horns at all because it would kit my 3/4 ton frame first. that said, you should be able to put 3/4 ton axles under it and do most anything you would want to. the springs are of course stiffer on 3/4 ton too
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 07-13-2005, 11:36 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
if your 3/4 ton axles are from a 67-72 they'll bolt up.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 07-13-2005, 01:57 PM   #5
panhandler62
Java Mechanic
panhandler62's Avatar
The opperative word here is FREE....
Go get the dang thing and worry about the details later.. ROTFLOL!
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 07-13-2005, 02:05 PM   #6
FUNMUDDER
FUNMUDDER's Avatar
well said.
Old 07-13-2005, 05:21 PM   #7
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
^Yeah, what they said. Go get it and see what the dealyo with it is first.
-Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 07-13-2005, 10:32 PM   #8
uncle_handsome
Uncle H. is this cartoon
uncle_handsome's Avatar
How about other years like the 73-87's and 88-98's? Is the metal thicker in their 3/4 ton frames too? How much?
I looked at an old C1500 (88-98) GMC at my college that was parked for years with its bed removed. I took a machinists ruler and measured the frame thickness between 0.110" and 0.135".
uncle_handsome is offline   Reply With Quote
Old 07-13-2005, 10:57 PM   #9
Blue_71
Bloo
Blue_71's Avatar
i dont really know uncle, that is a good question though.. if i had a way to measure i could check on my 89 k2500
Old 07-14-2005, 05:37 PM   #10
uncle_handsome
I've heard specs for the new Super Duty F*rds.
Their older chassis used to be 0.255" thick on the models starting in the late 90's. The 2004 model has a chassis 0.285"! (about double the thickness on the 88-98 GM ton)
BTW anything as thick or thicker than 0.250" is considered "plate metal" not sheet metal.
If you're interested you could probably check the frame thickness just by looking under the truck with a flashlight and machinist's ruler (something that measures 1/100's of an inch) a micrometer or vernier calipers; as long as the chassis is still an "open-C channel" shape in the back. That's what I saw on the 1/2 ton GMC, open C channel.
