Old 07-15-2005, 02:05 AM   #1
cheyenne10
cheyenne10's Avatar
temperature guage
What are obvious reasons why temp. gage sits in off position. It it hooked to senor on block with green wire headed towards firewall and into a harness.
Any common things to look for? (all other gauges work)
Bob
cheyenne10 is offline   Reply With Quote
Old 07-15-2005, 07:45 AM   #2
byrd
Union Electrician
byrd's Avatar
Not totally sure what you are asking for, but is it going all the way too hot and staying there? or is it not moving at all? Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 07-15-2005, 09:20 AM   #3
cheyenne10
cheyenne10's Avatar
Not moving at all
Randy;
This one just sits in cold or off position and never moves up when warm. Appears like it isn't even connected. I was wondering if there are common symptoms that might cause this like gauge dying or ? Or other question would be how should I go about trouble shooting it?
Bob
Old 07-15-2005, 10:01 AM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
The sender might be bad. Try grounding the wire from the sender and turn the key on and see if it goes all the way to hot.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 07-15-2005, 10:02 AM   #5
cheyenne10
cheyenne10's Avatar
strange missing posts
I just got a notification in my email that said the following post waw made but it doesn't show up on boards for me. This also happened a few days ago.
"Hello cheyenne10,
jhow66 has just replied to a thread you have subscribed to entitled -
temperature guage - in the The 1967-1972 Chevrolet & GMC Pickups Message Board
forum of The 1947 - 1998 Chevrolet & GMC Pickup Message Board Network.
This thread is located at:
http://67-72chevytrucks.com/vboard/s...1&goto=newpost
Here is the message that has just been posted:
Check to see if it is plugged in here (tan wire):
Bob
Old 07-15-2005, 10:08 AM   #6
jhow66
jhow66's Avatar
Sorry that was me--deleted it--had fuel gauge on my mine.
"Hello cheyenne10,
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 07-15-2005, 10:18 AM   #7
byrd
Union Electrician
byrd's Avatar
Bob
I went out to my truck and the engine is at operating temp and I was getting 3.8 vdc across the terminals connected to the printed circuit. You could check that to see if you are getting power to the gauge first. I'm not sure if the voltage measurement stays the same with a different engine temp, but the resistor on the back of the gauge should have about .072-.076 ohms of resistance, not sure on the scale so might be off a decimal or two Make sure the key is off when you check the gauge for resistance. Hope this helps, Randy
Zip:40272
Old 07-15-2005, 10:20 AM   #8
byrd
Union Electrician
byrd's Avatar
Excellent point
Zip:40272
