Old 07-16-2005, 12:29 PM   #1
PMS
Lowering truck
My son wants to lower his 72 GMC longbed. If we use 2.5" spindles and 2" drop springs will this be too low for a daily driver. Also he is 17 years old.... When you lower the front that much do you need to change shocks? Forgot to add he will be running 15x8 rally wheels with 255 / 60 tires.
Thanks,
Parrish
PMS is offline   Reply With Quote
Old 07-16-2005, 01:13 PM   #2
Joe67
67 is sold
By running lower coils, you'll need different shocks. a 4" drop is fine for a Daily Driver, he'll just have to be more careful at the bottom of some driveways, speed bumps, etc.
What are you going to use to drop the rear? Is it leaf spring or coil spring?
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 07-16-2005, 03:44 PM   #3
PMS
It is a leaf spring rear. I was going to contact a local spring company to handle the rear after we got the front done.
Old 07-16-2005, 04:29 PM   #4
Joe67
67 is sold
Check a couple of board vendors, they sell drop kits for the front and rear
www.gmcpauls.com
www.mothertruckers.net
Old 07-16-2005, 09:43 PM   #5
TN70C10
and lowered all the way around looks soo much better...
TN70C10 is offline   Reply With Quote
Old 07-16-2005, 11:02 PM   #6
68C15
blood type; Retumbo
68C15's Avatar
Lefty has about a 5" front & 7" rear drop. I run 3/4 ton shocks with no problem.
not to mention I have the same front tires with 275/60 's on the back. clearance is sufficient
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
