Old 07-14-2005, 02:17 PM   #1
jtminton
II Timothy 4:2
jtminton's Avatar
Idles high when hot
My truck idles high when the engine has been running awhile. If I exit off the highway, especially. If I give it a little gas, it goes down almost back to normal, but the next time I stop, it's the same thing.
What causes this? Is it a problem, other than annoying me?
BTW, it's a 72 350 with a quadrajet.
72 C-20 2WD LWB Custom Camper Deluxe 350 4 Speed "Project Lazarus"
MY TRUE PRIDE AND JOY
"Dangit, Bobby, people will see that oil stain and think I'm a drunk."
jtminton is offline   Reply With Quote
Old 07-14-2005, 02:54 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Had the exact same problem with an 86 camaro, it had a 305 and q-jet. Never did figure out what caused it, (was "borrowing" the car while I was saving up for my z-71 so I never fixed it.) I suspected it was either a malfunctioning choke or a vacuum leak somewhere. I have also read that q-jets are great until they get old. They start to deteriorate and develop gasket leaks and other little quirks that cause them to start "acting up." Hope you find the problem.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-14-2005, 03:50 PM   #3
jtminton
II Timothy 4:2
jtminton's Avatar
The puddle of gas on my intake manifold is evidence of that!
Old 07-14-2005, 05:25 PM   #4
gman
Check the throttle return spring. Pop the hood and manipulate the throttle by hand. Then pull a bit on the linkage to see if it will move and thus drop the idle. The spring may just be worn out and not pulling the throttle completely back.
72 Chevy SWB Custom Deluxe K10, 350/SM465, PS, PB, Fact. Air
2000 Harley...Wide Glide
gman is offline   Reply With Quote
Old 07-14-2005, 05:26 PM   #5
jtminton
II Timothy 4:2
jtminton's Avatar
I'll check that when I get home. Thanks!
Old 07-18-2005, 08:27 PM   #6
franko72
Franko72
franko72's Avatar
Vac. leak on hoses, Vac leak on carb gasket, Vac leak on intake manifold gasket. Do carb. gumout on all carb linkage and throttle shafts
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach
My Home Page
Better to burn out than it is to rust
franko72 is offline   Reply With Quote
Old 07-18-2005, 10:15 PM   #7
still w.i.p '68
Dreams are free
still w.i.p '68's Avatar
while its running spray b12 around the carb to see if any vac leaks'
my thought is you have bad carb base gasket. good luck
'68 swb fleetside
originally w.i.p '68
member since 1-01
w.i.p = ( work in progress )
still w.i.p '68 is offline   Reply With Quote
Old 07-19-2005, 02:15 AM   #8
4x4Poet
After the suggestions above, check the vacuum booster for a leak. Does the rig stall sometimes when you step on the brakes? Are the brakes hard to apply. The booster check valve is also in play as is the hose connection (could be cracked).
Brake booster troubleshooting
*A restricted vacuum hose will cause boost to drop off when the brakes are applied in rapid succession. This happens because the blockage slows the return of vacuum in the booster.
To check engine vacuum, connect a vacuum gauge to the supply hose that runs from the intake manifold to the booster. A low reading (below 16 inches) may indicate a hose leak or obstruction, a blockage in the exhaust system (plugged catalytic converter, crushed pipe, bad muffler, etc.), or a problem in the engine itself (manifold vacuum leak, bad valve, head gasket, etc.).
The condition of the diaphragm inside the booster is also important. If cracked, ruptured or leaking, it won't hold vacuum and can't provide much power assist. Leaks in the master cylinder can allow brake fluid to be siphoned into the booster, accelerating the demise of the diaphragm. So if there's brake fluid inside the vacuum hose, it's a good indication the master cylinder is leaking and needs to be rebuilt or replaced. Wetness around the back of the master cylinder would be another clue to this kind of problem.
To check the vacuum booster, pump the brake pedal with the engine off until you've bled off all the vacuum from the unit. Then hold the pedal down and start the engine. You should feel the pedal depress slightly as engine vacuum enters the booster and pulls on the diaphragm. No change? Then check the vacuum hose connection and engine vacuum. If okay, the problem is in the booster and the booster needs to be replaced.
Vacuum boosters also have an external one-way check valve at the hose inlet that closes when the engine is either shut off or stalls. This traps vacuum inside the booster so it can still provide one or two power assisted stops until the engine is restarted. The valve also helps maintain vacuum when intake vacuum is low (when the engine is under load or is running at wide open throttle). You can check the valve by removing it and trying to blow through it from both sides. It should pass air from the rear but not from the front.*
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 07-19-2005, 05:17 AM   #9
cowboy33713
Howdy;
recalled that some QJets had a "hot idle compensator", which was ( usually) a small bi-metal heat sensitive strip in a small recess in the rear of the carb.
Don't recall exactly how they worked, (it's been 20+years since I needed to know this), but a Rochester carb book should describe it and it's function, as well as how to tell if it needs replacement. If other avenues don't pan out, check if your QJet has one.
cowboy33713
cowboy33713 is offline   Reply With Quote
