Old 07-15-2005, 11:47 PM   #1
solarus81
C2500 to K2500 ('70 GMC)
Here is the story,
Got a '70 GMC 402/400 14 bolt FF, ac cab, etc. I'm wanting to convert this thing to 4wd.(I know ) I dont want to swap frames. Anyone out there do this kinda thing?
I plan on doing light offroading/mudding and highway driving. Want the ratio to be around 3.07 (dont ask) overall.
First step would be putting the front axle under it, but only RWD, then put in the transfercase and front driveline.
If it's too much a PITA, just swap the whole thing for a 1 ton or 3/4 with a crap body.
Anyone?
solarus81 is offline   Reply With Quote
Old 07-18-2005, 01:56 PM   #2
BobS
BobS's Avatar
It will be much easier and cheaper to swap frames. Find a 4x4 with good running gear and swap it all over at the same time.
Bob
V-6....only GMC Trucks have it!
62 GMC W5000 NAPCO-V6
65 GMC 2500 NAPCO Panel-V6
66 GMC 1000-V6
66 GMC 1500-V6
67 GMC K1500-SBC (originally a KM-V6)
68 GMC C1500-V6
68 GMC C1500-V6
68 GMC Suburban C2500
70 Chevy K20-SBC
71 Chevy C30 Longhorn-SBC
72 GMC Suburban C1500-BBC
72 Chevy C10-SBC
72 GMC C5500-ToroFlow Diesel
BobS is offline   Reply With Quote
Old 07-18-2005, 08:27 PM   #3
solarus81
Sure... it's easier... but have you tried to find a 4wd 3/4 ton 67-72 chevy truck in Washington state for $300? I havent. Besides... I want to be different.
Old 07-19-2005, 06:32 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I went 600 miles to get my rolling chassis that is now my 71 Chevy.
I've seen a 2wd that was converted to 4wd it originally had a coil rear.
The problems w/ that 402 will be, location it sits forward and needs to move back to keep the axle from hitting the oil pan. Also needs to go back for front driveshaft length. Of course if you fine a divorce transfercase from a 69-74 dodge w/ cross member then it would not be too bad. You'll need the front spring brackets and and the brackets for the rear of the front springs. You'll also need to move your e-brake cable where it goes through the fram as that's where one of the rear brackets goes. Also where the rear of the front springs bracket goes you'll need to hammer the frame flat. PM yukon jack he has a buddy w/ a 70 1 ton dually that was converted to 4wd.
If you have leaves in the rear then your good to go, except if you want to lift it, the 2wd leaves are narrower than the 4wd leaves.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 07-19-2005, 10:53 AM   #5
ckhd
ckhd's Avatar
I had a friend that did this, and he says he was stupid for doing it. He also says he will NEVER do it again.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 07-19-2005, 10:54 AM   #6
ckhd
ckhd's Avatar
Oh, and by the way, he's a mechanic for a living, and a CAT certified welder.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Old 07-19-2005, 09:42 PM   #7
Fireballs
I have a 1969 3/4 ton 4.09 front and 4.10 rear end pulled in the yard. Also an old blazer frame you can use for hangers, and a core TH350 with NP205 case with drivelines somewhere in the bed of a truck. I should have a PS box also.
I will take $250 for the parts.
Bring trailer if you want the blazer frame.
Bellingham, WA.
Fireballs is offline   Reply With Quote
