07-21-2005, 12:27 AM | #1 |
PROJECT 7DEUCE
Need some pump and pulley help
I am gonna get some new pulleys for my 454 chevy in my 72 1/2 ton. Are you guys with big blocks running the short water pump or long and how many grove pulley's are you running? I am gonna add air so I am gonna guess that I will need the 3 grove set-up? Any info or advise would be great..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
07-21-2005, 01:02 AM | #2 |
If you are ruuning short pump and have ps. you need the inner 2 groove crank pulley it runs ac and alt, the outter is a add on that runs the ps, water pump is a 2 row. I have a couple available. I can take pictures if you need to see what they look like. I also have a couple of the long water pump. the long water pump crank pulley is a 1 piece 3 groove. Burnsman has a picture posted in the for sale section
