I got a 87 2wd lb to put on my 4x4 frame and looking to unload the extras 100%
complete 5.7 engine, wing nut to drain plug with all the efi stuff you need computer, harness, fule lines , dual tanks with pickups everything engine has 98k but there is a rod knock so it will need crank/ bearing kit. most likely. $400.00 takes it all. 700R trans shifts nice would say it's never been apart but who knows fluid is clean. $150.00 drop in and go. complete 5 lug front/ rear setup. this will be the complete frame ,rear,suspension all that stuff It is a LONG BED FRAME. very clean $200.00 if you want it all with the engine / trans still together on the frame that works to and you get the I don't have to take the sheit apart discount $500.00 and off you go. complete tilt colum setup with auto shifter and signal/cruise stalk built in $75.00 Chevy silverado tailgate with a very nice filler panel , only a small ding on the top very easy to fix and a 3 inch strip of exterior surface rust on the bottom edge, just blast in and fill with a few weld beads or cheepo filler. $100.00 various other items left fom my crashed truck body , see pics in message board area. ask if you see something you need. |
AttentionDeficitDisorder
whats shipping on the 700r4 gonna run? colorado 80645? complete with converter and flywheel?
I will have to check on that for you if someone knows off there head chime in but from PA to yo I'm thinking about $150.00
