It's Done When It Runs!!
For you guys with a 350. What kind of oil pressure are you guys running at idle when warm? I am running about 20 psi. It goes up the more I am in the gas up to about 60 or 70. Idle seems a little low to me. Thanks in advance
Watch out for your cornhole !
![]() Join Date: Jun 2003
GM's guideline is 10 psi per 1000 rpm. So, at an 800 rpm idle, 8 psi is minimum. 20 is plenty at a hot idle.
Cool, thanks, I thought I read that somewhere, but I thought I would ask the experts to be sure.
Having issues
at idle, flow is what counts. You could have zero PSI and still be OK, as long as oil is flowing. (tho have a seriously worn engine)
