Old 07-22-2005, 09:44 PM   #1
squint
squint's Avatar
Question Truck wont start!!
Last night I went out to start my truck and had the oddest experience..
I turned the key and everything was fine.. i heard the engine fire so i let off the key and it did not quite start..
I turned the key again to finish the job, and all I got was a "click" ...
its acting like the battery is dead.. but I dont think it is.. The lights and everything come on full brightness.. but when i turn the key they go out completely.. there is no way that I can see that the battery would die like that?..
Any ideas.. started messed up?.. short somewhere??
I am just about to go take another look and see what I can find.. but I am pretty stumped..
squint is offline   Reply With Quote
Old 07-22-2005, 09:44 PM   #2
squint
squint's Avatar
Oh.. and i also tried jumping it.. no luck.. it would just go Rurrr Click.. and nothing..
Old 07-22-2005, 09:48 PM   #3
full foot notch
try screwdriver starting it on the starter, to pretty much bypass the starter solenoid?
should be either 2 big posts like the early 90 fords, on the starter, or 2 studs and a little wire, which should be the "kickover" wire, at which i would take an insulated screwdrive from the battery hot post to the little stud
if ya can screwdriver start your truck, its most likely the solenoid in the starter that is bad
full foot notch is offline   Reply With Quote
Old 07-23-2005, 03:36 AM   #4
squint
squint's Avatar
Man Oh MAn OH MAN..
Oh man.. get a load of this.....!!!!!
I went in and picked up a new starter to replace my old one. ( am pretty sure now that its the starter ) .. Well i opened the box and the small wire terminal was broken off.. !! ..
not only that but also..!!!!!
as i was crawling around under my truck i found that my fuel line was wedged right up agains my headers!!!.. the engine flex wore a hole in the fule line.. and gas has been leaking out right ONTO my headers!!
So now.. I have removed the main fuel line and the starter.. hopefully tomorrow i will get all the pieces i need and be back in action..
I am GLAD my started got messed up.. probably saved my life.. or at least my trucks life.. geeeesh.. I feel like going and beating on the guys who installed my headers..
Old 07-23-2005, 01:58 PM   #5
BALDMIKE
Enormous Member
BALDMIKE's Avatar
Yep.... Someone was looking out for you !
"79" Chevy Stepside 350/350
Check my Blog @ www.BaldMikesWorld.blogspot.com
BALDMIKE is offline   Reply With Quote
Old 07-23-2005, 05:21 PM   #6
a28doc
'87 V20 4x4
a28doc's Avatar
if it isnt the starter then check your inline fuses from the battery to the starter and also from the switch to the starter these things tend to get corroded really bad and wont let the truck start but the headlights and stuff will still work I had this happen to my K5
Doc
'86 K5 Blazer 4x4 FOR SALE
'87 v20 4X4
'99 S10 Blazer 4X4
a28doc is offline   Reply With Quote
Old 07-23-2005, 06:36 PM   #7
86swb
Born a Chevy Man
86swb's Avatar
You are really lucky. Glad you found that leak before the truck caught on fire. You must have had your angel with you and this was the only way to tell you of the problem.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
Old 07-23-2005, 11:14 PM   #8
squint
squint's Avatar
just got all the new fuel lines and stuff.. going to install them now.
Old 07-24-2005, 12:05 AM   #9
MM in NM
After you get the new fuel lines in make sure your battery connections are clean and tight.
MM in NM is offline   Reply With Quote
Old 07-24-2005, 03:58 AM   #10
squint
squint's Avatar
Fuel lines are all good now.. YAY.. no fires..
Cant figure out the starter though.. i have like 9 shimms in there and its still gumming up on the flywheel.. something is not right..
any ideas?
Old 07-24-2005, 10:18 AM   #11
Nolowrider
Nolowrider's Avatar
This may sound dumb, but did you make sure it was in park? Sometimes mine will do the same thing and I just jiggle the gear shifter alittle and she starts right up. Don't mean to insult your intelligence, but sometimes it is the smallest thing we overlook.
Nolowrider is offline   Reply With Quote
Old 07-24-2005, 01:44 PM   #12
squint
squint's Avatar
ya, i checked.. I pulled it out and into gear like 4 times.. shes in park alright.
Old 07-24-2005, 02:26 PM   #13
full foot notch
bad neutral safety switch?
Old 07-24-2005, 02:33 PM   #14
squint
squint's Avatar
where do i check that ?
Old 07-25-2005, 10:22 AM   #15
86 GMG
bottom of the steering column is where the n/s switch is i belive it is about 3 inches long and contours the round column
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 07-25-2005, 11:17 AM   #16
MM in NM
If your neutral safety switch is bad you will not get even a click from the starter. Just like if it is good and you try to start the truck while it is in one of the gears.
