The Beginning
![]() ![]() Last edited by littlejimmy; 07-20-2005 at 11:49 PM. |
![]() Join Date: Feb 2001
This will be a good place for info. I wont say everyone will always agree on things here but you will get a opinions on everything. Will this blazer be taken off road or just maily a street truck???? Lift or leave it alone?
BTW welcome to the site. ![]() Last edited by Mudder; 07-20-2005 at 11:51 PM. |
It is going to be lifted( the old man will crap himself when he see's how I "wreched" a good truck.), Mostly street but with well mannered off road capability's. I have put a great deal of research into springs and shocks looking for a good combination and have somewhat decided to go with tuff country springs with blisten shocks. My goal is 35's, I am still battling myself between a 4" or 6" lift. Would like the body to ride as low as possible without to much carving. I will be towing a 14'x7' cargo trailer a few hundred miles a month so maybe airbags will be in the trucks future as well.
Here is a pic of my daughters Blazer with 35's x 15.50's, a 4" tuff country and 3 inch body lift. I think it would be alright without the body lift.
Chevys Kick A$$
Damn, thats a sweet looking Blazer!
-Later
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
SKINNY TIRES RULE!
Welcome to the board from Seattle. Sounds like you've got a good project. If you go with a 6" lift, you may consider cross-over steeriing. It might make it a little more stable with the tires and towing. Also, on a '73, get the brace welded into the frame around the steering box.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Bouncytruck,
I am mechanically inclined and the crossover steering seems to be complicated. I have never seen the system on a vechicle so I am concerend that if I retreive all of the parts I will still not know what I am doing. Pictures say a thousand words..... but seeing in real life is a dictionary. |
mudder 67 did you give that blazer to her.that is one of the nicest i have seen in a while.very clean not all the bolt on crap.
I helped her get it from a friend when she got out of HS. She then had a guy paint it that more or less ripped her off with very poor body work. It's not in very good shape today as it sits.
you should have kept the doge and swapt over the drive trian to the blazer. But from ware you are now go with 6in BDS springs in the front 2in springs and shackle flip in the back. 14blt ff rear axle in the back and update the d44 in the front to 3/4 ton. by a good set of axles for the D44 and find a 14blt with 4:10 in it allready then you will only need to regear the front. Get a detroit locker for the rear and the front buy a disk break kit for the 14blt off ebay . stainless break lines and do the cross over steering it is cheap if the 73 has flat top knucles I cant remember if they do or not. you most likey have a 203 transfer case in it but ut may be a 205 if its a 205 good if its a 203 look for a 205 but keep the 203 incase you ever want to build a doubler. Next get new high angle drive shafts with CV joints. All of that will suck up around 3K. After that depending on what you have left after you buy rims and tires. While your doing all of that have the trans rebuilt and the engine gone threw you didnt say what it had for engine and trans but I would guess that guy the time both are rebuilt you wont have a lot left for body work.
Earl 68 2500 4x4 GMC Burb |
'87 V20 4x4
if your only going for mild offroad Id save my money on the crossover steering and replace front end parts when you do the lift on it Id recommend a 4" lift as you will be still towing a trailer you will need a 6" drop ball. If your serious about upgrading the brakes Id spend a little more money and buy a front disc brake upgrade kit which has larger rotors and calipers this will set you back about 600 bucks. Id then buy myself a good crate motor from GM performance and rebuild your tranny. as far as rearend goes Id find a used 14 bolt FF and rebuild it with a locker installed with at least 4.10 gearing or larger and also rebuild your front dana with same gearing make sure you put in new u joints in front and rear shafts 1350's preferrably. If you do all this and do most of the work yourself you still should have a ton of money left to work on body and interior. Best advice I can give you is shop around for the best prices and deals and gl in your endeavor and welcome to the board
Doc
'86 K5 Blazer 4x4 FOR SALE '87 v20 4X4 '99 S10 Blazer 4X4 ![]() ![]() |
