L.E.D. Tail lights, Baby!
9 bolt rear end?
I have seen alot of articles in magazines about certain restos using a F@rd 9-inch rear end. What is the 9" referring to? Also what does a posi do for me that a non-posi do?
Prov 3:5-8 "Hook 'em" L.E.D. Taillights for sale NOW!!! If interested, visit: www.earlyclassic.com or our website: www.jmcled.com All 67-72 GM Taillights are on sale untill 5 p.m. on Dec 15th, with Guaranteed Christmas delivery! joel.mcwaters@jmcled.com |
Official Beaver Inspector
A 9 inch rear end is refering to the size of the ring gear. A 9 inch is comonly used by racers because it has larger pinion size and is generally stronger than a gm 12 bolt (here we go!) A posi rear end basically makes both tires push the truck instead of one tire. A must have item for high horsepower/torque engines.
70' C-10SWB beater with a heater, one day haulin a$$ with class |
So does the 9 inch have 9 bolts?
no, it has a completely removable third member, we use them on our pro mods because you can change gears without setting up the back lash, etc, just unbolt it and put a different one on. They are fairly common and came under alot of fords. i have one under my 35, thought about doing it in my 68 also.
the late 70's lincoln Mark V's are the same width as the 71-72 12 bolts and you get disc brakes and with a little modding a parking brake that's incredible (aka i can't move my truck with it on) and they're the same bolt pattern
68 short step, 406/700r4, 9" w/discs. |
