Old 07-26-2005, 01:13 PM   #1
farside847
farside847's Avatar
Road noise, rubber floormats
Rubber mat:
Since I am going to be putting in new seats, I thought I would replace the
old and torn rubber floor mat. I decided to keep the rubber mat instead of carpet. It just feels better to me, like one big floor mat. Plus super easy to clean. I was looking around for a new mat and found them at all the vendors. Anyone have any quality issues I should be aware of? Are they all the same? It would be nice it they would also cover the floor under the seat, but I think they all have tails. Has anyone seen one that was full? The pic on Brothers looks full, but It is the same pic they use for all of the mats.
Road noise:
At the same time I should replace the padding and try to cut down on the road noise. What is the best stuff to use? The Jute padding, or something more high tech. Where does most of the noise come through - the floor, firewall, doors, glass?
I know allot of guys on here have done this and I am looking for some advise. Thanks!!!!!
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 07-26-2005, 01:41 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
All of the above! The firewall and floor, especially the firewall, will let in a LARGE amount of heat too if left bare. Mice ate my firewall insulation and it smelled bad, so I pulled it all out.... holy heck if you couldn't feel every degree of heat comin from that motor.... I bought some of that thin flexible insulation from lowes. I think its only 1/4" thick, and it's silver on both sides, I'm going to try that this winter if I ever get around to it. A lot of folks use the spray in sound deadner stuff on the inside of the doors and the back of the cab and something like dynomat on the floors and firewall. Let us know what you do and take pics
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-26-2005, 05:05 PM   #3
cdowns
cdowns's Avatar
www.coollizard.com good stuff you get what you pay for
Old 07-26-2005, 07:41 PM   #4
Green Machine
Green Machine's Avatar
Check the board members, but LMC and JC whitney have a full coverage, extra thick vinyl/rubber floor mat with some padding installed. When we redo my 1970, that's wht it's going to get. I will add the factory type foam and rubber/asphalt sound deadner underneath, got that stuff from mother truckers,covers most of front and rear area and you don't have to cut it. I will leave the more expensive cut to fit stuff for those who have more patience than I have, I think this will work good enough.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 07-27-2005, 11:05 AM   #5
farside847
farside847's Avatar
Coollizard looks like cool stuff, but you also need a special sprayer... It says it doesnt work with a paint sprayer, bummer.
Anyone used the mat from LMC yet?
Old 07-27-2005, 02:05 PM   #6
cdowns
cdowns's Avatar
you don't have to spray it on ,i use a small trim roller and regular paint brushes to apply it and get good results. it has the consistancy of a thick milkshake cleans up with soap and water
Old 07-27-2005, 02:11 PM   #7
farside847
farside847's Avatar
mmMMmm. Milkshake
Where did you apply it? I was thinking floor and the backs of the door panels...
Old 07-28-2005, 10:42 AM   #8
farside847
farside847's Avatar
Also, I called LMC, they now only have the rubber floor with tails...
Old 07-28-2005, 12:12 PM   #9
wolfthing2000
JC Whitney has the vinyl with a backing of some type full floor 150 dollars. I have heard that the vinyl type are a slick feel though.
wolfthing2000 is offline   Reply With Quote
Old 07-28-2005, 12:21 PM   #10
Alexis
Member since 2000
Alexis's Avatar
there this stuff called brown bread you can get off ebay. It like Dyno-mat but thinner and cheaper. Members have had good review with it. All you need is a roller and a heat gun. Just make sure you clean the surface first.
Alexis is offline   Reply With Quote
Old 07-28-2005, 01:10 PM   #11
knsmodels
I make Models
knsmodels's Avatar
I have the rubber floor mat in my truck and used Dyno-mat under it....I have been quite happy with the results so far......interior noise is down from what it used to be with the original floor mat.....I also sprayed a good amount of rubberized undercoating inside of my doors......Paul
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
Old 07-28-2005, 02:23 PM   #12
cdowns
cdowns's Avatar
mmMMmm. Milkshake
i'm in the middle of a streetrod project and it's being applied to the floor(inside and out) the inside of the firewall the quarters and inside the ddoors
Old 07-28-2005, 04:28 PM   #13
71-longbed
Its Magically Delicious
71-longbed's Avatar
sorry for the hijack ...can you remove the stock firewall pad without destroying the tabs that hole it in ??
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 07-28-2005, 08:55 PM   #14
BubbaGreen
removing the original....cut the ends off the tabs that hold it in (if they are plastic) if they are rubber, skirt em with wd-40 and push or work them thru from the opposite side. New ones (exactly like the originals-rubber) are available from chevyduty. That way you wont damage a good "original" insulation.....
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 08-04-2005, 05:50 AM   #15
4x4Poet
On another sound deadener thread, someone posted this link:
http://www.lobucrod.com./
Looks like a great product. Heat resistant, waterproof, mallable, and no adhesive demands.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
