Old 07-25-2005, 02:31 PM   #1
TireSmoke420
One of the few GMC'ers
TireSmoke420's Avatar
!?!?Brakes Quit Working!?!?
i was on the way to the store earlier today and my brakes stopped working. upon sum investigating i found that the rear compartent thing on the master cylinder is empty aint filled it back up yet but i checked the lines and none are broken. but im asking if the rear compartment is for rear tires or what so i know what brake cylinder to check. front or rear ones. ohh and how do i bleed drum brakes this is the first times ive had to do such a task done plenty of disk brakes.
TireSmoke420 is offline   Reply With Quote
Old 07-25-2005, 03:35 PM   #2
jhow66
jhow66's Avatar
Power brakes? No brakes at all? If you got a dual master cylinder you should have had some brakes left. Run line down from master cyl. to see which is which.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 07-25-2005, 03:39 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
If it's not leaking out somewhere underneath the truck, the master cylinder is bad and allowing the fluid to escape out the back. It will either run down the firewall or into the booster, depending on if you have power brakes or manual.
Drum brakes bleed just like disc brakes. There is a small bleeder nipple on the backplate of each brake. Usually a small wrench like a 5/16 fits it.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 07-25-2005, 04:12 PM   #4
Normally the rear reservoir is for the front brakes, and the front for back....but that is not a hard fast rule. You may just have lost a front wheel cylinder and your rears are out of adjustment enough to make it feel like no brakes. As mentioned it could very well be the master cylinder has gone out on you also.
BTW that is what mine felt like when I lost the front wheel cylinder on my 70 drum/drum setup.
Old 07-25-2005, 04:33 PM   #5
rambler
MOVE OVER
rambler's Avatar
what everyone said... my son's car did the same thing,, no leaks,, found out it was the master cylinder,, typically the rear is the front.. but not always... dont forget to bench bleed the M/C if you replace it.. good luck
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 07-25-2005, 04:45 PM   #6
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
My truck did the same thing, master cylinder took a dump and leaked into the booster. I couldn't figure out where the fluid was going till I pulled it off. Took it to O'reilly's and got a rebuilt one for about $20.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 07-25-2005, 06:52 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The 1/2 ton has the rear feeding the front and the front feeding the rear... and the 3/4 and one ton has the front feeding the front, and the rear feeding the rear...or is it the other way around?
I know the 1/2 ton is one way, and the 3/4 & one ton are the other way.
Old 07-25-2005, 07:26 PM   #8
guyryan100
guyryan100's Avatar
On my 1/2 ton the front is connected to front and rear to rear.
guyryan100 is offline   Reply With Quote
Old 07-25-2005, 09:51 PM   #9
68haywagon
I'm watching you!
My '68 is front/front-rear/rear. I replaced everything when I got the truck. Now you have me thinking I put the lines on wrong . It stops so I guess it'll be alright.
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 07-25-2005, 10:17 PM   #10
My truck has the Bendix HD brake system, and it's front master/front brakes, rear master/rear brakes.
RJD
Old 07-27-2005, 12:01 AM   #11
TireSmoke420
its got power brakes. it does have brakes but only with the peddle about to the floor. when usually its starts grabbing like 1/4 way down. truck is a 3/4 ton
Old 07-27-2005, 09:19 AM   #12
Alan Potter
IMO...add more fluid, pump the pedal and I'll bet you find that you do indeed have a rusted out line.
'12 Silverado Crew Cab 4x4
'05 Silverado SWB
'67 Chevrolet CST 2wd
'49 Willys Jeepster
Alan Potter is offline   Reply With Quote
