Old 07-28-2005, 12:36 AM   #1
Low69CST
it looks like your headers are ceramic coated. I've been told that is enough of a insulator that it keeps the heat inside the tubes and not much radiates in the engine compartment. However, I have heard of brake fluid boiling. I changed my lines like Mario to outside the frame and bought some insulation and wrapped the lines. I think the closest I get is about 1.5"-2". You may want to look on the other side under the truck. Where the rear line goes from the crossmember to the pass. frame rail was actually touching my headers. I had to change them around to the outside the frame rail.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
