cracker
Help With Tune UP
I dont really know what my truck is supposed to sound like if it is running right, i just got a new carb, and have hei ignition, how do i go about tuning it up, how do i know if it is running rich or lean, or if he timing is off? (dont havea gun. ) thanks yall.i wish i had some expert here with me who could do it in all of 3 minutes. hj
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Harry John Albert III located in Phoenix, AZ 1972 GMC JIMMY, 1969 lwb Chevy Frame, 1999 bmw k1200 ltc 1992 Kawasaki concours 1991 bmw k75 1973 cortez motorhome |
![]() Join Date: Mar 2000
Borrow or buy a timing light and vacuum gauge and use the instructions on our tech tips page for vacuum gauge use. Heres a link to it
http://www.gmcpauls.com/Tech%20Tips1.htm Without a vacuum gauge there is no way to get your fuel/air mixture dialed in precisely. You can pick up a timing light for as low as $19-$20 and a vac gauge for less at most auto parts stores and the you know they will be used again and they will save you more money on fuel mileage realised in the long run than doing it without them. GMCPaul |
ok here is a wierd one for ya. My 67 w/ 350 and edelbrock 600cfm is stalling on me when I make a left turn. Could this be something to do with the float in the carb?
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
cracker
just wondering, this may sound stupid which vacuum connectoin should i hook up my vac advance to? i used to have it on the fron but this new carb ahd a lil vac hook up on the side. just curious.
