Old 07-30-2005, 09:55 PM   #1
GloryHound
Working on a Nova.
GloryHound's Avatar
A-Arm shafts.
Just to let you all know these are an SOB to remove. If you don't have a hot wrench I would not even attemt to do it. Also it helps if you have a socket of the correct size. Since I have found out my Upper drivers A-Arm is bad and Lower Passenger side A-Arm are bad I have to remove these from my parts truck, I will have the proper sockets this time instead of banging my knuckles to heck using a pipe wrench.
GloryHound is offline   Reply With Quote
Old 07-30-2005, 10:21 PM   #2
walker
walker's Avatar
I just did mine. fortunatley I have wrenches up to 1 7/8" so I just put them in the vise and wrenched it out. I was impressed with how little wear was on the shafts. In fact, I had bought all new hardware for the rebuild and the brand new parts had more play in them than the old parts. I just used the old parts and bought new seals for them.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 07-31-2005, 06:11 AM   #3
cowboy33713
Howdy:
Just finished up a major front end rebuild on my 67; ditto on needing the proper (huge, 3/4"drive, impact) sockets. As I didn't, nor any 3/4" drive breaker bars nor a 6 foot length of pipe to use as a handle extention, I took my arms to a shop equipped with air impact tools. THAT was easy! Couldn't see buying everything for a one time job if I didn't have other use for it all. It's not like an arc welder or hot wrench!
cowboy33713
cowboy33713 is offline   Reply With Quote
Old 07-31-2005, 09:02 AM   #4
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Mine came out fairly easy with the help of a 3/4 set....didnt look that bad after 30 years of use either....
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 07-31-2005, 09:50 AM   #5
ChevyDude
Harbor Freight sells a cheap 6 piece set of JUMBO wrenches all the way to 1 7/8" for about $24 bucks and change....it was worth it to me and did the job fine!
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
