Old 07-30-2005, 03:48 PM   #1
c10crazy
Like a Rock!
c10crazy's Avatar
Generator light in dash stays on
In a plain 69 cluster, what would cause the generator light to stay on?. I put a tester on the battery and got 12.5 volts. I did the key off drain test with a tester and have had no problems. Any ideas?
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 07-30-2005, 04:18 PM   #2
jhow66
jhow66's Avatar
Stays on with key off or when running?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 07-30-2005, 04:22 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
was that 12.5 with the engine running??
Old 07-30-2005, 04:36 PM   #4
c10crazy
Like a Rock!
c10crazy's Avatar
jhow66- stays on when driving
Longhorn man- that was with the engine off
69 LWB
Old 07-30-2005, 04:44 PM   #5
Longhorn Man
what does the read with the engine on? The light will always be on with the ignition switch on and the engine off.
If it is on when the engine is running, it is supposed to mean you aren't charging.
Old 07-30-2005, 04:48 PM   #6
c10crazy
Like a Rock!
c10crazy's Avatar
I'll have to test it with the engine on to see what it reads voltage wise. When I'm driving down the road it stays on all the time.
69 LWB
Old 07-30-2005, 05:22 PM   #7
Longhorn Man
You may not be charging.
On my old '70 longhorn, the light stayed on, and for no reason. Since I had installed after market guages under the dash (I don't trust 35 year old dummy lights) I just ripped the bulb out and called it good. (after verifying it was in fact charging)
Old 07-31-2005, 12:06 AM   #8
jhow66
jhow66's Avatar
This might help:
Old 08-01-2005, 08:13 AM   #9
c10crazy
Like a Rock!
c10crazy's Avatar
Thanks for the pic. How do I test my alternator to see if it's bad???
69 LWB
Old 08-01-2005, 10:09 AM   #10
jhow66
jhow66's Avatar
Take it to one of the parts stores-AutoZ--Advance etc.
Old 08-01-2005, 11:40 AM   #11
1968GMC
love my truck
1968GMC's Avatar
do this test. undo your - battery post, then with a test light toutch the - post and with the other end of test light toutch the unhooked batt cable. If the light on tester lights up uou got a short somewhere
While the light is lit up, unplug the voltage regulator. If light goes out then thats your probleme.
1968GMC is offline   Reply With Quote
Old 08-01-2005, 11:53 AM   #12
c10crazy
Like a Rock!
c10crazy's Avatar
I did the test light trick to check for a drain and it didn't light up. Can I use a multimeter on the alternator to check to see if it's bad?. If so, how?
69 LWB
Old 08-01-2005, 09:34 PM   #13
Longhorn Man
That test light deal only helps to locate a drain, not a faulty charging system.
Fire up the truck, and just place the leads on the battery. If it is less than 13, then you need to do more troubleshooting.
Placing the lead on the large red wire on the back of the alt will give you the same reading as on the battery, but the battery is easier to get to when the engine is running.
Old 08-01-2005, 09:54 PM   #14
c10crazy
Like a Rock!
c10crazy's Avatar
Well, I went to drive the truck today and it wouldn't start up . Last weekend I had to give it a hot shot and then it was fine. The battery is only 2 years old. The regulator looks fairly new but the alternator looks nasty. I put the battery on a 3 hour charge and it reads 13.5 volts sitting on the workbench. I think I'll take the alt. in to test it and go from there. I always heard something about starting the truck and while it's running disconnect one of the cables and if it dies it's the alternator. Is this dangerous to do?
69 LWB
Old 08-01-2005, 10:00 PM   #15
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
It's only dangerous if you let the pos. cable touch a ground when you do that with the engine running. I've done it before to check the alternator on my truck and I'm still alive.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 08-01-2005, 10:05 PM   #16
c10crazy
Like a Rock!
c10crazy's Avatar
which cable am I supposed to remove when it's running?
69 LWB
Old 08-01-2005, 10:37 PM   #17
Longhorn Man
The cable test will only tell 1/2 truths. If your alt is only putting out one amp, your engine will still run at an idle.
You can remove either cable, but the neg cable is safer to remove.
Old 08-01-2005, 11:51 PM   #18
68haywagon
I'm watching you!
:andy:
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 08-02-2005, 12:03 AM   #19
Longhorn Man
LOL, my computer was messin up...I had thought the board went down again.
Old 08-02-2005, 09:29 AM   #20
motocrosschump
Mine stayed on when my Coil was tightened down good enough..
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
