Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 08-03-2005, 12:11 PM   #1
Mudder
Mudder's Avatar
Ttt
Mudder is offline   Reply With Quote
Old 08-04-2005, 07:00 PM   #2
1972ChevyCheyenne
We use chains on the farm. I think our big chain we use for pulling and lifting is 1/2 inch grade 70. I think the most dangerous thing you can do is jerk on stuff. That's when things usually break. If it don't move get a bigger tow vehicle. For heavy stuff like tractors in mud another option is to use two tractors to pull it out. Hook two seperate chains/straps to the stuck machine and pull away from each other at a 30 degree angle or so. Creates a bow effect and the stuck vehicle should move. And if your really screwed
you can dig you around and pull. They also can lift the vehicle up and over a bump. And while their are their they can dig a tile in and fix the ones you broke.
Jamie
1972ChevyCheyenne is offline   Reply With Quote
