Old 07-31-2005, 12:38 PM   #1
gator2511
gator2511's Avatar
Anybody know who makes this mag?
These were on my truck when I bought it and I'm trying to find out who makes them and where they can be bought. Anybody know?
gator2511 is offline   Reply With Quote
Old 07-31-2005, 12:45 PM   #2
matthufham
looks like the american racing wheels you can get at discount tire.
matthufham is offline   Reply With Quote
Old 07-31-2005, 01:12 PM   #3
da-burb
"Ochre Ogre"
da-burb's Avatar
American Racing model AR 136 if my memory serves me correctly.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 07-31-2005, 04:28 PM   #4
gator2511
gator2511's Avatar
It looks a lot like the AR 136 but the center section of my wheels are round and the lug nuts are tight against the center hole. Its a small difference but it doesn't look the same as the wheel on the AMR website.
Old 07-31-2005, 05:23 PM   #5
shifty
Questionable
shifty's Avatar
It looks like something that Ultra used to make when I was in high school.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 07-31-2005, 05:54 PM   #6
71swb4x4
71swb4x4's Avatar
Don't use the distance from the lug nuts to the center hole as a judge to determine that they are not the AR 136's. If you have a tight bolt pattern the holes will be close, but if you have a more open bolt pattern they will be farther away from the center hole.
Example 5x4.5" will be closer to the center hole than 5x5"
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-31-2005, 06:08 PM   #7
gator2511
gator2511's Avatar
Thats what I'm afraid of shifty. I really love the mags but I have no spare tire and if anything happened to one of them I would be in bad shape. Thats why I'm trying to id them. I removed one of them and cleaned the inside of the wheel. I brushed it with a bronze brush and could not find a manuf. name anywhere. Here is what I found around the inside of the center rim. (1 15x10 , O.W.I. , DOT-T, not to exceed 40 psi, max wheel load not to exceed 1900 lbs) Inside two of the spokes was stamped A8196 and BH1996. I feel like an archeologist trying to I.D. some ancient unkown artifact.
Old 07-31-2005, 06:13 PM   #8
gator2511
gator2511's Avatar
You have a great point 71swb4x4. Maybe I should go to a local dealer and see if he can help. Thanks.
Old 07-31-2005, 09:17 PM   #9
al's71gmc
4 eyed fever
al's71gmc's Avatar
i had the same problem with a gmc safari van a few years ago. i had new tires put on and the tire shop broke one of my wheels (of course they wouldn't admit it). they went ahead and sent my wife home with a 5" by 1/2" chunk missing out of the inside edge. it had the same vague numbers and no brand name. even the dealership where i bought the van new could not identify it. i never did get a matching replacement. good luck but don't hold your breath.
1971 GMC 2500 4x4
1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto.
4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!!
al's71gmc is offline   Reply With Quote
Old 07-31-2005, 11:40 PM   #10
shifty
Questionable
shifty's Avatar
I know one of a few companies makes this wheel:
Prime, Ultra, Eagle (American Eagle), American Racing.
I swear it's Prime or Ultra. I can't find anything at either site, probably because it's discontinued. It was really popular around the time thoese damned sawblade rims were big.
Here's something Eagle makes that's damned close:
http://www.aewheel.com/wheels_detail.cfm?id=27
Which is basically the same as the American Eagle Ventura:
http://www.tires-n-parts.com/wheels/...d_ventura.html
NOTE: both of the wheels in the pictures are 5-lugs. I would almost bet that if you'd find a picture of the Eagle Venturas in a 6-lug pattern they'd match what you got.
Old 08-01-2005, 12:09 PM   #11
Rdub
Ran in to this same problem a year ago..... bought a 41 chev flatbed hotrod that a guy had lost interest in, had a set of "ultras" on the front which I wanted to match.... looked and looked & was told they're not made anymore.... the AR"s are pretty close with exception of how the "spokes" tie in to the rim... the Ultras are straight whereas the AR's have a bit of an angled sweep to them.
Rdub is offline   Reply With Quote
Old 08-02-2005, 09:21 PM   #12
gator2511
gator2511's Avatar
Well I went by an American Racing Wheel dealer today and he said it was definately not his wheel. He said it was probably an old Ultra but they don't make that wheel anymore. So, thanks to all you guys for your help but I guess I'll have to keep looking around and maybe I can turn one up.
Old 08-03-2005, 03:14 PM   #13
CyberRanger
CyberRanger's Avatar
If you pop the tire off the bead, there should be some identification cast/stamped into the area between the beads. There may also be a part number somewhere on the inside of the rim. Worked in a tire shop while goin' thru school years ago & saw a lot of those markings.
'71 K20 Custom Deluxe - 1 owner - Original 350 & 4 spd, Rams horn dual exhaust, Centerforce clutch, K&N 4"x15", factory tow hooks, 4" Skyjacker Softride, Rancho RSX9000s, custom Firestone AirRide overloads, 36" 305/85R16 10ply Buckshot Mudders, 4.11 gears
CyberRanger is offline   Reply With Quote
