Flamin' Bass
OK, I'm ranting, but this is the THIRD fuel float in less than 3 years that has decided it wanted to sit on the bottom of my poly Blazer tank instead of floating. Now I get to find a way to drain ~15 gals of gas, drop the tank and pull the float.
Does anyone have an alternative to the soldered brass(?) float, like maybe a plastic one, or would a cork do the job? Rant off.... Thanks,
Rick Olson /nosto/ Galloway, NJ Pics : http://community.webshots.com/user/nosto53 1972 Triumph TR6 - full resto, now with a Toyota 5-speed 1975 F**D F-100 - rusty, but reliable 1982 HD XLH-1000 1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!! |
Try patching JB-Weld on it. We used it on a John Deere float and it worked great. Gas resistant, good stuff!!!!
Sisyphus was my mentor!
![]() Join Date: Sep 2002
when I was having my tank coated, the guy offered to dip my float as well. he said it was an easy fix. try your local rad shop that does tanks. as for draining it, I had to do it the (yuck!) old fashioned way & siphon it out. Just have a few gas cans on hand...
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car Last edited by passthebuck; 08-02-2005 at 06:09 PM. |
Just run the gas out of it. In fact, if you know what kind of mileage you get just go fill 'er up and calculate how many miles you can drive on a full tank and go drive that many. Then just drop the empty tank.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
Im with Walker on this one. Just go cruisin.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
get a new float and drown that sucker with seal-all available at any hardware store
![]() Join Date: Dec 1999
I have had 3 to come back to me in the last couple of weeks!!!
