Old 08-03-2005, 10:06 AM   #1
burlapen
burlapen's Avatar
Newbie with 61 Custom Cab Question
First of just wanted to say hello. I just purchased a 61 LWB cust cab with 350/th350. Body is rough, but it is a good starting point. I installed new back glass yesterday using the rope trick (no fun but it finally went in) I am having trouble getting the lock bead in there as the gap is very tight in the corners. Any suggestions. Thanks.
burlapen is offline   Reply With Quote
Old 08-03-2005, 11:28 AM   #2
60-66 Nut
Professional Beer Tester
Welcome to the board, and congradulations on your new old truck. It really doesn't look that bad, especially for it's age, I've seen much worse. According to the hood, grille and fender badges it's a 62, 60 & 61 had the hood with the pods around the signal lights and the grille had four headlights. It could have been an early 62 and was titled as a 61. As for the window gasket, yes they can be very tight in the corners, especially some of the new replacements. I usually lube them up with armorall or son-of-a-gun, and that helps a little. Just be sure to wash it all off the body before doing any body work. Best of luck.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 08-03-2005, 03:01 PM   #3
burlapen
burlapen's Avatar
Talking
Thanks....I knew the hood was different, all of the wiring is only for single head lights and looks to be original, but who knows. It does have the torsion bar suspension though, so the chassis must be 62 or earlier right? Got the gasket finished up today, pulled the truck out in the sun to get the gasket nice and warm, then used wd-40. Now its time to start on the body!!!
Old 08-03-2005, 04:48 PM   #4
60-66 Nut
Yes, 60-62 had the torsion bar front suspension.
60-66 Nut
85 GMC Short Bed
86 GMC Short Bed
92 GMC 1500
Old 08-04-2005, 09:42 PM   #5
Mongo
YES_____NO
Mongo's Avatar
Great looking truck!! Good luck and hope you find all the info you need here.
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown
Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984
Help support the board
Mongo is offline   Reply With Quote
Old 08-08-2005, 02:51 AM   #6
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
Burlapen,
I love the truck.
Do you by chance have a pic of the th350 crossbrace? I made one for my '62 that is bolted up to the 2 inner frame rails(X part of frame) to miss the torsion bars.
TIA,
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
Old 08-08-2005, 04:31 PM   #7
V-6 Fix
There is a small special tool to get the window bead installed. You can get it at any of the parts houses, Brothers, LMC or Chevy Duty. Try NAPA also.
Jake
V-6 Fix is offline   Reply With Quote
Old 08-08-2005, 05:51 PM   #8
burlapen
burlapen's Avatar
Thanks for the responses guys. Chevyboy, I will try to snap a pic of the crossmember.
Old 08-10-2005, 03:00 AM   #9
Chevyboy1962
C10 now is a GMC
Thanks Burlapen.
David
