08-09-2005, 10:54 PM | #1 |
needin' money
woohoo!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i was putting a flexplate on my truck at a friends brothers shop today,anyways my old (305) engine is at it to, on an engine stand, i took a break in between puttin the flexplate on and called my mom and had her write down the numbers, like i said (my lil 305) turns out to to be a 350-#14010207,and the heads are 462624, do the heads flow better than the 882's, i wish i would have known this earlier, i spent about $1800 in a 350 i built during the past school year, and i still have to buy better heads, like i said about the numbers, that is according to www.mortec.com, also are there any other good sites for #'s
SWB Stands for Short Wide Bed |
08-09-2005, 11:13 PM | #2 |
Post the numbers stamped on the block in front of the passenger head . I can tell you what it is from these numbers . Frank
08-09-2005, 11:23 PM | #3 |
needin' money
next time i go down there, i will get them, which, since i have a 350 will be a couple weeks, so i can refresh it, all i can say is stock rebuild , and a smaller cam than the one i built, maybe a 270 or a 280 comp magnum cam, or another lunati voodoo
08-09-2005, 11:34 PM | #4 |
The block casting you gave shows a 1980-1985 Corvette and the heads were used on 1979-1985 350 / 400 cu in motors . I will be able to tell you exactly what it came from when you post the engine stamping that is on the block . The heads should be 1.94 intake valve heads with 76 cc chambers . I do not know how they flow compared to 882's . Frank
08-09-2005, 11:56 PM | #5 |
Right turn Clyde
This is all I could really find about the cylinder heads
http://www.hotrodders.com/forum/miss...ber-19935.html 270 and 280 Magnum are still pretty big that is where you need to start checking valve clearances and things like that running a 270 or bigger cam.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
08-09-2005, 11:58 PM | #6 | |
Project 2 Resume
I already answered on the double post in the engine & drivetrain board.
John 1984 C30 Chevy Crew Cab Dually 1998 Jeep Cherokee 4x4 2004 Chevy Trailblazer 4x4 (wife's) 1970 Mustang FB fully tubed (getting 521 BBF & powerglide) 1978 Nova 2dr (going BBCaddy & S.P. th400) 1984 Monte SS (circle track car) |
08-10-2005, 12:30 AM | #7 |
I found the info I posted on this web page
http://www.chevy-camaro.com/chevy-ca...gine-codes.asp It shows Corvette???? as a use for the block . The valve size I posted is what they show to have left the factory with . They dont show 1.72/1.5 as a factory offering so they probably arent 1.72's . The stamping is what I always use to determine exactly what it came from since many blocks were used in several different applications . I was just trying to give a little info on the subject . Didnt mean to step on any toes ! Frank |
08-10-2005, 03:40 AM | #8 |
Project 2 Resume
Those valve sizes I stated above, are factory sizes with the 624's. Unfortunately not all data references online are 100% correct. "Corvette" just makes it worth more. Anyway, you didn't step on anyone's toes.
