Old 08-14-2005, 11:48 AM   #1
matt_field
matt_field's Avatar
how much hp, can th350 handle?
im having a 396 bb built up for my 72 shortbox, i want to install a th400 but not looking forward to getting a different yoke and gettting the shaft cut..... should i just stay with a th350? or is it worth the work to a th400? thanks!
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 08-14-2005, 12:05 PM   #2
cdowns
cdowns's Avatar
turbo350's can be built to take over 800hp
Old 08-14-2005, 12:11 PM   #3
Randy70C-10
Randy70C-10's Avatar
I had one built for my Model A running a 6:71 blown 350 (ported heads and all that other crap)...680 horses.
Randy70C-10 is offline   Reply With Quote
Old 08-14-2005, 12:40 PM   #4
Burnsman
Chevy Freak
Burnsman's Avatar
th350
Ran 9.12 on one in a 73 camaro.
69 GMC SWB, 350
70 Chevy LWB, 350
55 chevy gasser, 461
73 Camaro, 496
67 RS Camaro, 406
64 Chevelle, 588
71 Nova, 565
67 Camaro, 461
Burnsman is offline   Reply With Quote
Old 08-14-2005, 02:06 PM   #5
GMC AMI
GMC AMI's Avatar
They are a lot tougher than given credit for!
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 08-14-2005, 02:18 PM   #6
chevymad
My friend ran one in a lifted 77 4x4.. big tires, 500hp 454.. tranny outlasted the truck.
chevymad is offline   Reply With Quote
Old 08-14-2005, 02:30 PM   #7
Purs
Got Big Block?
Purs's Avatar
are you rebuilding the TH350? It's doubtful any of the one's mentioned are anywhere near stock. They can undoubtably be built ($$) to withstand alot of punishment. It also depends on how bad your going to treat it(just street tires or track/slicks...). For peace of mind I went ahead and swapped in a TH400, because I didn't want to be swapping transmissions frequently. Most likely, if you're talking about a cruiser/ street tire smoker, the 350 will be fine.
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 08-14-2005, 03:52 PM   #8
junkyardjohn
junkyardjohn's Avatar
GENERAL MOTORS NEVER PUT A T-350 BEHIND A BIG BLOCK. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 08-14-2005, 05:34 PM   #9
ratrod67
ratrod67's Avatar
I have a T350 in this. 612hp, 738ft tq. Definately not stock but not too bad. $250 in the rebuild and $400 in the converter. Has a manual valve body, shift improvements, ect.
ratrod67 is offline   Reply With Quote
Old 08-14-2005, 05:47 PM   #10
Purs
Got Big Block?
Purs's Avatar
very nice.
Old 08-14-2005, 09:17 PM   #11
86swb
Born a Chevy Man
86swb's Avatar
ratrod67, Bad ass car you have there. Nice. Love the yellow with the black strips.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
Old 08-14-2005, 11:38 PM   #12
Randy70C-10
They never put one in a Model A Ford Either.
Old 08-15-2005, 06:56 AM   #13
GMC AMI
GMC AMI's Avatar
GM also put the best truck motor in a car!
Old 08-15-2005, 02:43 PM   #14
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
Th___
Make sure you get the heat treated sprag and drum no matter what.. The sprag is the weakest link in the Turbo trans. You also get to keep a little more power with the 350 over the 400. Go with the TH350
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 08-15-2005, 02:58 PM   #15
GMC AMI
GMC AMI's Avatar
Run it!
Keep the 350 unless it acts up and then worry about an upgrade. I ran a stock one in a Buick Stage 1 455 with a slight cam with only a B+M shift upgrade kit and it lasted thru 2 drag seasons with 0 problems! I sold the car and it still snapped your head off on the shift points! Not too hard to change a tranny on a 2 wd.
Old 08-15-2005, 09:22 PM   #16
Orence1
Orence1's Avatar
Matt,
I am running a TH-350 on a 72 LWB with a 450hp 402. I spent about $450 on a rebuild and I don't anticipate any problems at all. BTW, I think you will need to have the drive shaft shortened as a result of the BB. You will want to mount it in the forward set of frame holes to allow maximum firewall clearance for the distributor. Good luck. You will love the performance.
Larry
Orence1 is offline   Reply With Quote
Old 08-15-2005, 09:29 PM   #17
86swb
Born a Chevy Man
86swb's Avatar
Originally Posted by Orence1
I spent about $450 on a rebuild and I don't anticipate any problems at all. Larry
$450.00? Surely you did all the work yourself.
