#26 | |
Chevy Orange is still a longtime favorite and I would use it in a 'Heartbeat' if I had the opportunity.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
#27 | |
Questionable
tomatocity - I got your PM. I'm uploading the 20min part of the show for you. The audio and video are about 1 second out of sync by the end of the show and it's ~375MB in size, so I hope you're not on dialup ![]()
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 08-13-2005 at 08:09 PM. |
#28 |
What is the difference between POR15 and POR Engine Paint?
It would be good to see an unbiased comparison chart with all the different engine paints, prepartion, application, and finish. I will throw in another brand. I am going to use Rust Doctor on the rear frame and bed underside. I will post a thread after it is complete.
#29 |
Questionable
POR-15 is the name of the company. People just call it POR for short.
The only supposedly unbiased comparison I could ever find was on the body stuff, not the engine product. Nautrally, Eastwood saved it and published it at their site. That is here: http://www.eastwood.com/jump.jsp?ite...88&iSubCat=852 There was another thread about this at the forum that was relatively civil, but it also talked about the body stuff: http://207.44.196.117/vboard/showthread.php3?t=129741
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#30 | |
#31 | |
Happy to be here
![]() Join Date: Mar 2000
#32 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 08-14-2005 at 10:49 AM. |
#33 |
Experience with Por15
I work at a restoration shop and this is what we found with the por15 stuff. I haven't sprayed it on an engine yet.
This stuff sticks like sh*t to a blanket and is rock hard. We have not found anything else that compares to it in these respects. The down side to this product if you want to call it that is the prep and finish. If you don't prep the metal properly you are toast. IT WILL NOT STICK TO BRAND NEW METAL PERIOD!!!! (without prep) The prep is the biggie here. You have to either sandblast the new metal to create tooth. Or you have to use the cleaner/ metal prep system that they sell. If you do not you will have a disaster on your hands. We found even using 80 grit disk on the metal first was not good enough in some cases. I know that sounds nuts but that is what has happened. After talking with the por people they said that you should never use a solvent based cleaner to prep the metal. Thinks like acceton, final wipe etc are all solvent based cleaners. They said to use any water based cleaner like their own marine clean or things like the Castrol Purple degreaser. During the cleaning phase we use a scotch bright pad to scrub the surface clean. Rinse with free flowing water (hose). On really dirty stuff like suspension parts we used the solvent based cleaners to get the majority of the crud off then we did the final clean with the water based stuff. The metal etch is really important. We use the por metal ready with a scotch bright pad to scrub the surface. Make sure you keep the area wet and leave it for about 10-15 min. Now rinse off the excess with free flowing water (direct quote from por15 people). Do not use any thing to wipe the surface just the water. When you are done rinsing we used air to dry it off. The finish is the one thing that I have a hard time with. We reduce our paint 4:1 with the por solvent. I spray down two coats of the reg por then the last coat with the chassis coat black. I just can't get a nice finish. Granted I am a rookie to painting so bare that in mind. But for a nice chassis black finish I have yet to see anything nicer than Zerorust. So I will be painting zero rust as my top coat on any por parts that will be seen. Note: You can spray anything you want on top of the por15 product as long as you are in the recoat window. This will vary with temp but anywhere from 2-4 hours. Once it is set you would have to scuff the paint before anything would stick on top of it. Hope this helps Brad 73 Nova SS Hatchback 77 Nova Hatchback (stock car) 68 GMC Short Box Step Side |
#34 | |
Good info, Daxcor.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
#35 |
Weekend Warrior
Heads, Block, Timing Cover, and Oil Pan were all SPRAYED with POR15's Motor Black. Please note that this stuff goes a very long way...if spraying it only mix a little bit because you can't reuse it once you take it out of the can. I mixed a tad too much - there is about 5 coats on this motor
The Block and Heads were "Airless Shot Machined" which is like sandblasting, and the Timing Cover and Oil Pan Were GlassBeaded. (Valve Covers are Crinkle PowderCoated) I just scotchpadded the block down good then scotch padded it again with laquer thinner, and sprayed it. I didn't use thier regular Por Rust Paint first either. If it flakes of...I learned my lesson and will paint it again. If not no harm done. To be honest It doesn't bother me to take the motor back out if i have to paint it again. It is only going in an open fendered P/U. Oh and the paint has cured for about a 1 year @ this point ![]() ![]()
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() Last edited by arkracing; 08-14-2005 at 10:01 PM. |
#36 |
Akracing, not to sidetrack the thread, but is that an oil filler spout on that valve cover? Nice. Please tell me what brand valve covers those are and what oil spout that is (assuming I'm right
#37 |
Weekend Warrior
They Are M/T's with the M/T Machined Off of them and the Breathers installed in their place. Yeh you pur the oil into the breather as well....you have to unscrew the top cap and take the foam filter thing out.
I bought them off a board member (superchevy i think) and he had them already powdercoated with the breathers already installed. the valve covers should be pretty easy to find (if not i have a set that are in pretty good shape that i would sell for $60+shipping) they aren't machined for the breathers either. the breathers you can get from www.mooneyesusa.com or your local swap meet or ebay. The ones on my covers are pretty old..as in original from the 60's or 70's. www.speedwaymotors.com has the "Offy" style which bolt into the side of the valve cover (they look better on small blocks...i.m.o.) Only problem with this set up is that i'm worried about positive crankcase pressure (the breathers might not release the pressure quick enough (like PCV that would suck the pressure out). I guess we'll find out. I'll just have a PCV hole machined into one side if need be
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() Last edited by arkracing; 08-15-2005 at 07:29 AM. |
#38 |
Questionable
If anyone else wants this Trucks! episode covering Engine Dressup, I need to know. Otherwise, I'm going to remove it from my website.
It's about 20 minutes of video footage and it's about 370MB in size. Shoot me a PM.
#39 |
Lovin' Life in Miss.!
Puttin in another good word for the por engine paint. I have sprayed it and brushed it. Thinned per their reccomendations it still sucked to spray. Turned out ok though. Even though I just KNEW those lil blobs were gonna show. Glad I was wrong. The brush I used on my first motor turned out just as good and was a heck of a lot easier to apply.
Only prep I did on the last crate motor was to wipe it down with marine clean. Still looks nice and it has been 10 months. |
