Old 08-18-2002, 03:59 PM   #1
Question Drum Brake Question
I'm redoing my brakes since my funtime yesterday. Anyways, when I pulled the front wheels, I noticed the drums need ground. It's been so long since I had front drums, do I need to chisel the drum from the hub before I take them to a shop to be ground or is it customary (safe) to leave the drums on the hubs.
Old 08-18-2002, 04:09 PM   #2
Zkast
Zkast's Avatar
As long as the drums and hub are still together and not loose its best to turn them with the hub. You'll get a better centerline when the drum is chucked up. Most auto parts stores will turn it for ya.
If I remember right, the stud shank is what holds the drum onto the hub, if thats the case... leave the hub attached.
Zkast is offline   Reply With Quote
Old 08-18-2002, 04:10 PM   #3
Southpa
Southpa's Avatar
When you say "ground" I assume you mean having them turned on a drum lathe to get the rough spots out, right? You can leave the hubs on and take them in as is.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
